Introduction: PVC Letter B
How to make a letter B from PVC pipes
Step 1:
Gather your materials. You should have 6 pieces of 1 inch pvc pipes, 1 pipe that is 3.75 inches, 2.5 inches, and 2 inches. Also have 2 90 degree connectors, 2 tee connectors, and 4 45 degree connector.
Step 2:
Connect the 1 inch pipe to the 90 degree connector.
Step 3:
The connect the 90 degree to a 45 degree connector
Step 4:
After that put a 1 inch pipe into that 45 degree connector and connect another 45 connector.
Step 5:
Now connect that 45 degree connector to a tee connector by attaching together with another 1 inch pipe.
Step 6:
The next step is like the first steps in which you connect to 2 45 degree connectors together and then connect to the tee connector.
Step 7:
Now connect the 2.5 inch pvc pipe to the 90 degree connector from the beginning.
Step 8:
Next attach the 2 in pipe to the tee connector. This creates the middle bar for the B. And then connect it to the other tee connector to.
Step 9:
To finish the bottom attach the last 90 degree connector to the 45 degree connector. Finally connect the missing peice which is a 2,5 inch pvc pipe.
