PVDRILL - PVC Drill Press
The idea is to build a "Rotary Tool" using low cost elements for routing, cutting, drilling and sanding, mainly PVC pipes. Something like "vertical drill" but simpler...
Picture - Source: Wikipedia
Supplies:
Logical Project (FreeCAD):
    1. 000-PVDRILL-V2.FCStd
    2. 001-COLUNA-V2.FCStd
    3. 001-SUPORTE-V2.FCStd
    4. 002-SUPORTE-RETIFICA-V2.FCStd
    Materials:
    PVC Pipes
    1. 20 mm (1/2") = 1x of 730 mm (28.74")
    2. 25 mm (3/4") = 1x of 162 mm (6.37")
    PVC Fitting Connectors
    1. 90° Elbow 20 mm (1/2") = 3x
    2. Tee 20 mm (1/2") = 6x
    3. Coupling 25 mm (3/4") = 1x
    4. Cross 25 mm (3/4") = 1x
    5. Tee 25 mm (3/4") = 2x
    Fasteners and Connectors
    1. Hex Nut (1/4") = 8x
    2. Flat Washers (1/4") = 8x
    3. Screws = 2x
    Others
    1. Threaded Rod (1/4") = 1x of 320 mm (12.59")
    2. PVC Glue
    3. Wires
    4. Button
    5. Motor DC 3V~12V - 20W
    6. Drill Chuck
    Teacher Notes
    Step 1: The Project
    I have identified some legal ideas searching the Instructables projects and the internet, so I went along with the idea of creating an outline for this project. A great reference was the design of PVC Dremel Drill Press.
    Step 2: Designing
    The project was divided into four structural elements: base, column, support and rotary tool. As a rule the possibility of disassembling each element and saving individually.
    Step 3: Building the Base Structure
    For this steps you need to cut PVC Pipes following this sizes and glue the PVC Pipes and Connectors following the image.
    PVC Pipes sizes:
    Type 20 mm (1/2")
    230 mm (9.05") = 2x
    130 mm (5.11") = 1x
    50 mm (1.96") = 2x
    Step 4: Building the Column Structure
    PVC Pipes sizes
    Type 20 mm (1/2")
    50 mm (1.96") = 1x
    230 mm (9.05") = 2x
    40 mm (1.57") = 2x
    Step 5: Building the Support Framework
    PVC Pipes sizes
    Type 25 mm (3/4")
    18 mm (0.7") = 2x
    36 mm (1.41") = 3x
    72 mm (2.83") = 1x
    Step 6: Building the Structure of Rotary Tool
    PVC Pipes sizes:
    Type 25 mm (3/4")
    36 mm (1.41") = 2x
    Step 7: Putting the Complete Structure Together
    Everything is prepared to be connected, so let's turn some connections.
    Step 8: Assembling the Rotary Tool
    To fix the motor I made a PVC holder and soldered the wires.
    Step 9: Mounting the on / Off Button
    Bonus idea.
    Step 10: Last View
    Well, first prototype and my first Instructables done. :)
    Step 11: Next Steps
    1. Adjust rotary tool
    2. Permanent power supply
    3. Base for fixing
    4. Vertical control shaft
    5. Speed control
    Be the First to Share
      • CNC Contest
        CNC Contest
      • Make it Move
        Make it Move
      • Teacher Contest
        Teacher Contest
