Pallet Pumpkin
2,702
14
6
About: I like to design and build random things.
This pallet wood pumpkin project was so easy to do from start to finish. It started with the last pallet wood I had disassembled last year. Then I scavenged from the kids craft paint stash. Some dry brushing the paint on and swiping it off and it was done in time for the little trick or treatsters.
Get started today and by the end of the weekend you will have it done!
Step 1: Tools/Materials
Tools:
  • Table Saw
  • Band or Jig Saw
  • Drill / Bit
  • Sander
  • Paint Brush
  • Pencil
  • Clamps
Materials:
  • Pallet Wood. Enough to make two layers 30" x 24"
  • Wood Screws and/or Glue
  • Paint
Step 2: Pumpkin Boards
I used 11/16" thick pallet wood for the top layer. The size is arbitrary but I settled on 30" wide by 24" tall. Using a table saw, cut the boards to length. You don't need to be super accurate since you can clean up the edges at the end.
Step 3: Pumpkin Shape
I used a few guidance lines to center the pumpkin shape on the board. Then, use your best artistic ability to draw a pumpkin. I went over the pencil marks with a sharpie so it would be easier to see on the saw.
Step 4: Cut Shape
Use a jig or band saw to cut the boards to make the shape.
Step 5: Fit Check
If you cut everything correctly, you should have a nice pumpkin outline.
Step 6: Backing Boards
I used thinner boards for the back (~ 1/2" thick). Cut enough to completely cover the back side of the pumpkin. Make sure that the boards have a lot of rough texture and prominent grain showing along the board. Try not to use boards that have already split along the edges.
Step 7: Fit Check
Do a quick fit check at this point. You might want to arrange the boards to get varying colors for the final layout.
Step 8: Paint
The goal here is to get a rustic/weathered look but also have something that sticks out. Select about four or five basic colors for the pallet boards. Be sure to include some blue/green/grey/white colors to contrast with the warm tones. I chose the colors orange, red, yellow, green and blue.
Three of the boards are painted an orange shade as the primary color. One board is used for each of the other colors. Dry brush (and I mean dry) craft paint onto a board. Wipe off excess paint while it is still wet. To tone the color down further, wipe with a damp rag. You can layer a few brush stokes of a similar color on top. Be sure to blend everything together with a rag or paper towel. Get creative and enjoy the process.
Step 9: Attach Boards
Once the paint is completely dry, glue and screw the backing boards to the pumpkin outline. Apply pressure and allow glue to dry.
Step 10: Final Pictures
Here is the finished project. This will go on our front porch along with the mums and pumpkins. My wife LOVED this project.
Step 11: More Pictures
Thank you for viewing!
Step 12: More Halloween Projects
If you like this project, check out some of my previous Halloween Projects.
    • Pie Contest
      Pie Contest
    • Organization Contest
    • Tape Contest
      Tape Contest
    6 Discussions
    seamster
    5 months ago
    I like it, it's simple and has a good fall/harvesty look to it!
    mtairymdseamster
    Reply 5 months ago
    Thanks. Even my kids said it looked pretty nice which is saying a lot :).
    Kink Jarfold
    5 months ago on Step 12
    I'm a big fan of pallet wood. What you did here and with the other projects at the end of the 'ible were great. Nice touch with the color variety showing through the pumpkin outline. KJ
    mtairymdKink Jarfold
    Reply 5 months ago
    Thanks. I like working with pallet wood as well. Mainly because I can blame the warped, cracked wood for my lack of woodworking skills :).
