Panic Alarm | Panic Alarm Using 555 Timer | 555 Timer Circuit | Electronics Projects
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today in this video tutorial i am going to show you Step By Step
How to make a panic alarm circuit using 555 timer ic
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
❖ Please Subscribe / Like Facebook Page ❖
https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
https://www.facebook.com/Circuit-DIY-122206971927...
You Will Find Full Project Description and All Useful Material Including
• Circuit Diagram / Schematic
• Hardware / Component List
• Code
• Datasheet
• Pin Configuration Etc
AT ► https://circuit-diy.com/panic-alarm-panic-alarm-u...
Thanks for Watching It.
↪ For Any Difficulty Please Comment Below
Step 1: Useful Material
❖ Hardware Required ❖
► 555 Timer IC
► 9V Battery with Clip
► Breadboard
► Jumper Wires
► 1K ohm resistor
► 22K ohm resistor
► 100K ohm resistor
► Mini buzzer
► 10uf capacitor
► 100pf ceremic capacitor
❖ Circuit Diagram ❖
Link ► https://www.file-up.org/700g2i7ves2k
Step 2: Useful Steps
❖ Steps ❖
STEP # 1 ( Connect IC )
► Connect 555 timer IC on bread board
STEP # 2 ( Make power connections )
► Pin 8 of 555 Timer – To VCC of Battery
► Pin 1 of 555 Timer - To GND of Battery
► Pin 6 of 555 Timer - To Pin 2 of 555 Timer
STEP # 3 ( Connect Resistor #1 )
► Connect 22K ohm resistor BTW pin 7 and pin 2 of IC
STEP # 4 ( Connect Capacitor )
► Connect 10uf capacitor BTW pin 2 and GND
STEP # 5 ( Connect Resistor #2 )
► connect 1K ohm resistor BTW pin 4 and GND
STEP # 6 ( Connect Resistor #3 )
► Connect 100K ohm resistor BTW pin 7 and VCC
STEP # 7 ( Connect capacitor #2 )
► Connect 100Pf ceremic capacitor BTW pin 5 and GND
STEP # 8 ( Connect button )
► Connect button or switch BTW pin 4 and pin 8 of IC
STEP # 9 ( Connect buzzer )
► Connect buzzer BTW pin 3 and GND
STEP # 10 ( Testing )
► Connect battery and test
    • Build a Tool Contest
    • Remix Contest
      Remix Contest
    • Warm and Fuzzy Contest
