Paper Airplane
30
1.Piece of Paper
2.Pen or pencil any color for personalizing your plane.
Teacher Notes
Step 1: Paper
Set one piece of paper on a flat surface. Printer paper or thicker paper works best for flight time and tricks, try different papers to see what you like. I used regular notebook paper and my plane crashed very quickly.
Step 2: Fold
Fold the piece of paper in half long way. Creasing the fold flat.
Step 3: Unfold
Unfold the paper with the creased edge facing downwards.
Step 4: Corner Fold
Fold the right and left top corners into the middle evenly until the side aligns with the middle crease. Creasing the fold flat.
Step 5: Fold Corner Again
Fold the same corners again on top of its self again to the middle creasing it again both sides.
Step 6: Folding the Top
Fold the top pointed tip down towards yourself, making the point align with the bottom flat edge.
Step 7: Fold in Half
Now fold the paper in half along the crease, but against the first crease.
Step 8: Fold Down Small End
The skinner side that is the nose of the plane, the slanted side needs to be folded down towards the main crease. Do this for both sides of the plane.
Step 9: Unfold
Now open back up the main crease showing the pointed tip upwards
Step 10: Fold Tip
Fold the tip back towards the top only to the last folds from step 7.
Step 11: Back in Half
Now fold the plan back in half with the previous folds showing on the outside.
Step 12: Bend the Wings
bend the wings down leaving a thin base for the body of the plane.
Step 13: Wings
Now fold the wing tops down towards the base of the plane just slightly.
Step 14: Back Draft
Now at the back of the plane in the middle of the folds you need to fold a small section about one inch in the reverse of the rest of the fold and crease it to create a small slant at the back base part of the plane at the center.
Step 15: Style
Now the fun part. add any color or style or pictures you want. I added Teeth like a A-10 Warthog. Many options be creative. Then go fly it. Lastly change small things, or material to see the changes until you find a plane you like.
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
    2 Discussions
    Trevor Laudreyobscura
    Answer 16 days ago
    I used regular notepad paper and it fell pretty quickly. Then used regular printer paper and it went a good 30+ feet before dropping.
