Introduction: Paper Flowers
These paper flowers are very fast and simple to make.
Step 1: What You Need.
You will need.......
1. Paper ( I like to use old music sheets or old books.)
2. Wire hangers
3. Ribbon
4. Hot glue gun
5. Pliers
6. Scissors
Have fun...
Step 2: The Hanger
First, straighten the hanger. Then you are going to want to cut about 15 inches of the wire. ( This is going to be your stem.)
Step 3: Paper
Now you are going to make the petals; you can cut them freehand or you can cut them with a pattern. If you cut them without a pattern, then you will get more variety. You are going to want a variety of sizes-- about four or five--and a LOT of petals.
If you want you also can curve the tops of the petals before you glue them.
Step 4: Making It
You start with the smaller petals and work your way up from there. You put a little hot glue on the wire end and place the first petal on. Then you start to assemble it as a rose, one petal at a time. Once you run out of small petals, you can move on to the next biggest.
Step 5: Finished
Flowers Challenge
Flowers Challenge
