Introduction: Paper Mache Pots
Paper mache, A.K.A (Papier-mâché). Is an incredibly simple process. In this instructable I will show you how to make a Biodegradable Paper mache pot. For transplanting plants directly into the garden.
Step 1: Material's You Need
You will need a
Muffin tin
flour
strainer
bowl
spoon
paper
water
Step 2: Soaking the Paper
First you will need to soak you're shredded paper in water.
Step 3: Pulping the Paper
Second you will need to pull apart and pulp the paper. If you like you could blend it but this is optional.
Step 4: Straining the Pulp
Next you need to strain and squeeze the pulp. Try to get almost all of the water out.
Step 5: Adding the Flour
Next you need to add some flour and water. Start out adding a few spoonful's of each and add more until it reach's a doughy consistency.
Step 6: Forming the Pot
Next put the Paper mache in the muffin tin and form the shape of a pot.
Step 7: Let Dry
The final step is to let the Paper mache dry for about 12 hours to a day. You can bake the pots if you would like to speed up the process. And that's it you have just made yourself some Eco-Friendly, Biodegradable, Paper mache pots.
Papercraft Contest 2017
