Introduction: Paper Snowflake Wreath
This is instructions to make a paper snowflake wreath. You can also use decorative paper and 8 X 8 inch squares to make smaller versions. Have fun!
Step 1: Fold Paper
Take your 8 1/2 X 11 paper and fold part of it into a triangle, leaving a long strip.
Step 2: Cut Excess Paper
Step 3: You Should Have a Triangle
You will need 6 of these.
Step 4: Fold Your Triangle in Half
Step 5: Mark Paper in Five Sections
3 cm apart. Use side that has two separate sides.
Step 6: Cut Paper at an Angle at Each Mark
Do not cut all the way through. Leave about 1 cm uncut.
Step 7: Your Cuts Should Look Like This
Step 8: Open Your Paper Up
It should look like this and you should have 6 of these.
Step 9: Fold Sides Into a Tube
Tape together.
Step 10: Turn Over
Repeat folding sides together into a tube and taping. Remember to keep turning your paper over.
Step 11: Once You Have Completed All Six Papers
Gather them together at the tips and glue dot or staple together.
Step 12: Take Each Side
And glue dot or staple each side together.
Step 13: Go All the Way Around Doing Each Side
Punch a hole at the top and add ribbon to make a loop for hanging.
