Paperclip Circuits - Papercliptronics
About: Logician. Interests: Computer Programming and Inventing. Electronic Circuits. Homemade Breadboards.
We Make Many Electronic Circuits on our Paperclip Breadboard.
Step 1: LED Light Circuit - Papercliptronics
LED Light Circuit on our Paperclip Breadboard.
  • (1) 150 Ohm Resistor
  • (1) Green LED
  • (2) D Batteries
We could use a 100 Ohm Resistor instead, but would be slightly overpowering the LED by 10 mA.
Step 2: LED Circuit - 6 LED
LED Light Circuit
  • (1) 100 Ohm Resistor
  • (6) White LED
  • (2) D Batteries
Step 3: Light Detector Circuit - Papercliptronics
  • 150 Ohm Resistor- for the LED
  • 120 Ohm Resistor OR 8.2 kOhm Resistor - Base of Transistor
  • pnp 3906 Transistor
  • LDR (Light Dependent Resistor)
  • LED
  • 2 D Batteries
Step 4: Dark Detector Circuit - Papercliptronics
  • 100 Ohm Resistor
  • 8.2 kOhm Resistor
  • npn 3904 Transistor
  • LED
  • 2 D Batteries
Step 5: Water Detector Circuit - Papercliptronics
  • 270 Ohm Resistor
  • 1 kOhm Resistor
  • LED
  • 2 D Batteries
Step 6: Dual LED Blinking Circuit - Papercliptronics
  • (2) pnp 3906 Transistors
  • (2) 180 Ohm Resistors
  • (2) 100 kOhm Resistors
  • (2) 470 uF Capacitors
  • (2) LED's
  • (2) D Batteries
Step 7: Resistors in SERIES
What if we don't have a 150 Ohm Resistor?
That's okay.
We can use multiple smaller Resistors together instead, to achieve the correct value.
We can place two 75 Ohm Resistors in Series and they will Add Together to become 150 Ohms.
The Series Formula for Resistors is very simple:
Resistor Total = Resistor1 + Resistor2 + ... ResistorN
(ResistorN means, however many Resistors you have, you add them all together with simple addition)
Step 8: Resistors in PARALLEL - When Only 2 Are Used
What if we don't have two smaller value Resistors either, but instead, we have two larger size Resistors?
That's okay.
We can use multiple bigger Resistors together instead, to achieve the correct value.
We can place two 300 Ohm Resistors in Parallel and they will Decrease the Total Resistance Value to become 150 Ohms.
The Parallel Formula for when ONLY 2 Resistors are used:
Resistor Total = (Resistor1 x Resistor2) / (Resistor1 + Resistor2)
Step 9: Resistors in PARALLEL - When 3 or More Are Used
What if we only have 3 larger sized Resistors and we want the value to equal less, such as 100 Ohms?
The Parallel Formula for 3 or more Resistors:
1 / ResistorTotal = 1 / Resistor1 + 1 / Resistor 2 + 1 / Resistor3
Step 10: Capacitor & LED Circuit
When we REMOVE power from the Circuit, the LED will Turn Off Slowly.
The reason for this is simple: The Capacitor is Discharging (LED Turns Off Slowly).
We USE a 470 micro Farad Capacitor.
If we used a bigger capacitor, the FADE OUT time would INCREASE. (longer discharge time)
If we used a smaller capacitor, the FADE OUT time would DECREASE. (shorter discharge time)
Step 11: Capacitors in PARALLEL
Step 12: Capacitors in SERIES - When Only 2 Are Used
Step 13: Capacitors in SERIES - When 3 or More Are Used
    • Sensors Contest
      Sensors Contest
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
