Paracord Daisy Chain
Introduction: Paracord Daisy Chain
Paracord has long been a staple of campers, and DIYers. It can be purchased in all kinds of colors now, the cord I used in this Instructable even has a strip of reflective fibers in it making it even better for camping uses as it will stand out in the dark and is less likely to leave you on your face when heading back to your bed or getting up for nature in the middle of the night.
One issue I have always had with paracord or any other rope is no matter how neatly I coil it I always ends up with a giant bird nest when using it; particularly when out in the field and there are bushes and branches for it to get caught on. For that reason I have gotten into the habit of always daisy chaining my paracord when I purchase a new length of it. This process take less than 10 minutes for a 50ft section and will save many headaches and much time down the road.
Supplies:
-Paracord (I used 50ft for the pictures)
-Lighter (to fuse the ends)
Teacher Notes
Step 1: Step 1: Fuse Your Ends
It only takes a moment and will ensure the longevity of your paracord. Be careful not to touch the end until it has fully cooled as the melting cord will stick and burn. There is no need to light it on fire, if you make a clean cut, a simple touch of a flame will melt and fuse it cleanly.
Step 2: Step 2: Overhand Loop
I start with a simple overhand loop knot.
Step 3: Step 3: the First Loop
To start off, I push the cord through the loop I had previously made.
I have seen other methods to start, this just happens to be my method of choice. It is easy and it holds.
Step 4: Step 4: Continue With Loops
Now you continue in a similar fashion. Push one loop through the previous, then tug on the line towards the end you started on to tighten the previous loop.
Step 5: Step 5: Play With the Cat
Cats are a great help when completing any kind of task with rope and string. Make sure to seek their council in the completion of your project.
Step 6: Step 6: Finish
When you have reached the end of your rope you can lock it down easily by simply feeding the end of the rope through the very last loop and pulling it tight. When it comes time to use the rope all you need to do is back out the end of the rope and start pulling and it will easily undo itself. By doing this we have taken 50ft of paracord and compacted it down to just over 10ft and have ensured that it is less likely to get tangled up.
Step 7: Step 7: But Wait! There's More!
To save on space, make it even more compact and easy to work with, I have gotten into the habit of doing the daisy chaining twice. Starting back at the beginning end I push a loop of the chain through the start and repeat the process again. When I reach the end, I again push through the end of the rope through the final loop. By doing this process I have now shortened the cord from 50 ft to just over 2ft. By making it thicker it is also easier to hold and manage while working with it in the field as I just slowly pull out the length that I need.
In the end I can prep 50ft of paracord in less than 10 minutes (depending on how much help the cat provides). It pays dividends when I go to use it in the field.
Rope & String Speed Challenge
1 Person Made This Project!
  • Sculpting Challenge
    Sculpting Challenge
  • Cardboard Speed Challenge
  • 3D Printed Contest
    3D Printed Contest
14 Discussions
SylvanB
SylvanB
Tip 6 weeks ago
This is also a great way to store extension cords. Especially useful with 50ft and 100ft outdoor cords. Once chained, multiple cords can be dumped into a bag or bucket for tangle-free storage.
And FYI, this is a basic crochet chain.
Wild-Bill
Wild-Bill
Reply 5 weeks ago
Thanks for the suggestion. I just went out and did up a 12 gauge extension cord. That is quick and easy way to handle them.
droberts_Frankfort-Schuyler
Reply 6 weeks ago
They are great at getting tangled up into giant messes, I have done this with them as well, it's a great help in preventing maddening extension cord bird nests.
Wild-Bill
Wild-Bill
5 weeks ago
I like your idea. I started mine with a simple overhand knot and I finished by taking the lead through the loop as it is simpler. I thought if one can do it twice why not three times. I happen to have a 100 feet of paracode at my disposal so why knot give a try. It is a simple lanyard knot which I have used before while making fancy lanyards mixed in with others knots that I learned from Ashley's Book of Knots. It was fun to try so thanks for your instructable.
oreonow3
oreonow3
6 weeks ago
Congrats! You just learned the chain stitch for crochet. I do this to my electrical cords too. They will never tangle when you crochet them :)
Reply 6 weeks ago
Thanks for the comment! I hope you enjoyed the Instructable. It's great how simple skills developed for one task can have so many various applications across other fields.
jcooperrider1
jcooperrider1
6 weeks ago
I've also seen this used for sound/microphone cabling, though you don't want to pull it too tight and put a strain on the metal core as it goes around the sharp turns.
Reply 6 weeks ago
That's a great idea, it would prevent some awful birdnest messes I bet. Thanks for sharing the idea!
jonas4321
jonas4321
6 weeks ago
Great instructions. I have never made the chain a second time, I will have to try that. I usually start by doubling or quadrupling longer pieces of paracord then chaining them, but I will try the re-chaining, thank you!
Reply 6 weeks ago
I'm glad you found it helpful. I do the single stand because I want to keep it use-able without undoing the whole chain first. I hope it was helpful.
rozzieozzie
rozzieozzie
6 weeks ago
This looks like crocheting a chain stitch without a hook. Not exactly, since crocheting starts with a different slip knot, but it's very close. And it's a good idea to keep the cord from getting tangled. Thanks for the instructional!
Reply 6 weeks ago
I'm glad you liked it! I hope you found it useful. Sometimes a reminder of something we already know or have used elsewhere is helpful for other uses.
seamster
seamster
6 weeks ago
Great instructions, and very useful. Thank you!!
