Parallel Port Network Cable Tester
Introduction: Parallel Port Network Cable Tester
About: DIY my way through life. For me, Instructales is a way of living. It's my making log. My life is counted with the instructables I make.
This is one of my earliest projects as a maker. Yes, this is an old ancient technology. But it's an old project I made in the past to document it on instructables.
This is a network cable tester I built with my brother using PC as the testing brain and the parallel port as the interface with the cable.
Here is my Channel on Youtube:
AeroArduino
Step 1: Components
Parallel Port cable. Old printer cable
2 RJ45 socket surface mount box
74157 2 Input Multiplexer
Step 2: Software
We used C to write this code.
Here are the steps of software operation flow:
- Sending Code to the shift register to configure which pins to choose.
- Sending signals to the parallel port on four terminals.
- Receiving signals on the parallel port to check for continuity.
- Sending Code to the shift register to configure which pins to choose the other four pins of the RJ45 connector.
Epilog X Contest
Epilog X Contest
Be the First to Share
    • Recycled Speed Challenge
    • Make it Move Contest 2020
    • Build a Tool Contest
