Parametric Design of a Shaft Assembly
About: Trust me, I am an engineer.
Parametric design is a process based on algorithmic thinking that enables the expression of parameters and rules that, together, define, encode and clarify the relationship between design intent and design response.
Parametric design is a paradigm in design where the relationship between elements is used to manipulate and inform the design of complex geometries and structures.
Grasshopper is a visual programming language and environment that runs within the Rhinoceros 3D computer-aided design (CAD) application.
Step 1: The Original Problem
The original problem is to be found in the Shigley’s Mechanical Engineering 10th edition problem 3.73.
In the main problem The Principal Stress are to be found. But in my study the goal is to find the rod’s diameter.
Step 2: IDEF Diagrams Generation
After specifying the input parameters, the required mechanisms and constant parameters are set. The required results are also to be set. IDEF diagrams are used to help set these parameters.
The IDEF process starts with the main block which is the "Create Shaft Assembly". Then this block is exploded into the main step functions of the process.
Step 3: Parametric Problem Generation
1.The solution of the program is initiated by entering the parameters. Also, setting the constant parameters are required.
2.After that, the program is to calculate the reaction forces at the pillow blocks.
3.From the reaction forces, the moments at each gear are calculated.
4.The diameter is then found by dividing to the maximum moment.
Step 4: The Control Parameters
First of all we need to specify the parameters that we want to control
•The Two Forces Magnitudes.
•The Forces Locations.
•The Length of the rod.
•The Gears Diameters.
•The Yield Strength.
•The Safety Factor.
Slider blocks are generated to represent these parameters accordingly.
Torque is also needed to be calculated initially.
Step 5: Calculating the Reaction Forces
The following parametric equations are used to calculate the Reaction Forces.
Grasshopper blocks are generated accordingly.
Step 6: Calculating the Moments
The following parametric equations are used to calculate the Moments.
Step 7: Calculating the Diameter
The following parametric equations are used to calculate the diameter.
Step 8: Visualization Blocks
These visualization blocks use the dimensional values of of the gears, pillow blocks and shaft to generate the CAD drawing representation of the assembly.
Step 9: Rendering Results
The CAD results are rendered in the Rhino program interface.
Step 10: The Full Canvas of the Grasshopper Interface
This is the full canvas of the Rhino 3D grasshopper interface.
Step 11: Further Results
These results can be saved as an .dwg extension to be opened in the Autocad and used for manufacturing purposes.
Step 12: Thank You for Your Time, Hope This Was Usefull!
    • Pie Contest
      Pie Contest
    • Tape Contest
      Tape Contest
    • Build a Tool Contest
