Personalized Winged Skateboard
Introduction: Personalized Winged Skateboard
Skateboard is a kind of extreme sport that young people like very much now. Before modeling, we searched the size and various components of skateboard on the Internet. Based on this, according to the actual and model ratio of 10:1, we used Tinker CAD platform to build skateboard, and decorated it with personalized elements.
Teacher Notes
Step 1: Fabrication of Base Plate
1.The board surface of the skateboard is a rectangle with length of 80mm, width of 20mm and height of 1mm.
2.The double warped part of the sliding plate is made up of a circle with a diameter of 20 mm, a height of 1 mm, a width of 20 mm, and a cuboid with a height of 1 mm and a hollow cuboid.
3.Rotate the double tilt of the skateboard by 22.5 °, and splice it with the board surface to form a bottom plate, so that players can play various kinds of fancy playing methods, and use blue as the base color.
Step 2: Making Wheels and Shock Absorbers
Considering the factors of force and experience, a shock absorber is added at the same time of making wheel to reduce the force on the bottom plate.
1.Considering the factors of force and experience, a shock absorber is added at the same time of making wheel to reduce the force on the bottom plate.
2.the wheels are made up of two wheels connected by a cylinder with a diameter of 3.5mm and a length of 22mm.
3.use the cylinder and the ring to form a connector, then use the spring and a cylinder to rotate 45 ° to splice with the connector, and then combine with the wheel to complete the overall production of the wheel.
Step 3: The Combination of Skateboard As a Whole.
The wheel, shock absorber and base plate are combined to form a complete skateboard, making it more complete, integrated and real.
Step 4: Personalized Decoration
Because the direct combination is too boring, we need to decorate the skateboard and add some personalized elements, such as graffiti and fins, to make the skateboard more beautiful and personalized..
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Fix It Contest
      Fix It Contest
