Personalized Wooden Cat Bowl Feeder
1,015
24
6
Introduction: Personalized Wooden Cat Bowl Feeder
About: Hi my name is David, I like to make things out of Wood, also like to take things apart and fixed them.
I don't know how many people on Instructables are Cat lovers, but I am. I have had cats, since I was a little boy, and my current cat, named Tiny, well she is special. So I decided to make her a personalized Cat Bowl feeder.
In this Instructable I will try and show you how I made it, I have also uploaded the video from my Youtube channel.
What you will need:
CNC Router, I used the X-Carve CNC
Cad/Cam program, I used Vectric Aspire
Wood 24" x 10" x 3/4", I used Maple
90* V-Bit
1/4" Endmill Bit
Table Router with 1/8" Round over bit
Sander and sandpaper
Minwax Gunstock Finish
Minwax Prestain wood conditioner
Clear Gloss Sealer
Kreg Jig
Clamps
Pocket Screws
Screw Driver and drill
Paint brushes
Tack Cloth
Paper Towels or Rags
2 Stainless Cat Bowls from Food City
Black & Pink craft paint
Step 1: Design and Preview
I designed my project in Vectric Aspire, after I made my vectors, I then added Toolpaths as shown in the pictures.
After all toolpaths was made, I ran the Preview, to see what it comes out like, if it's good, then we save toolpaths and begin to carve.
Step 2: Carve
Now is time to carve, after clamping my stock in the CNC, I first used a 90* V-Bit to carve the Paw prints, her name and face. Then installed the 1/4" Endmill and profiled the the holes and cutout the parts, leaving tabs to hold the stock together.
Step 3: Take Apart
Now use a small saw to cut the tabs off, to release the parts
Step 4: Route Edges
Now I installed a 1/8" Roundover bit into my Table Router, then took all the pieces over it, putting a slight round edge over the pieces, plus it also cleans up the tabs.
Step 5: Sand
Then we sand all the edges, plus the face parts that are going to show.
Step 6: Pocket Holes
Then I used my Kreg pocket hole jig, clamped the jig to the stock and drill pocket holes.
Step 7: Pre-Stain
After blowing off all the dust, wipe it down with a Tack cloth, then apply a coat of Minwax Prestain wood condtioner. Allow it to set for about 15 minutes before going to next step.
Step 8: Stain
Now apply a coat of Minwax Gunstock finish, let it set for about 15 minutes, then wipe off the excess.
For a darker color, reapply a second or third coat, to get the desired look for you. Then allow the parts to dry overnight.
Step 9: Clear Coat
After the stain has dried overnight, spray a couple coats of clear sealer, then allow it to dry overnight.
Step 10: Paint
Now take the Craft paint and a small paint brush, and paint the Cat Paws, Face and lettering as shown in the pictures.
Step 11: Sand Again
After the Craft paint dried overnight, take a piece of 220 grit sandpaper and gently go over the entire piece, removing any paint on the top edges. Then wipe down with a Tack cloth to remove any left over dust.
Note don't sand too much or you will need to reapply stain.
Step 12: Final Finish
Now spray a couple coats of Clear gloss finish and let dry.
Step 13: Assembly
Now clamp your parts and screw together.
Step 14: Cat Approved
Now add the bowls, food and water. Then get the Cat to approved your personalized Cat feeder, I thank she likes it.
Thanks for checking out my Instructable
1 Person Made This Project!
  • Mason Jar Speed Challenge
  • Bikes Challenge
    Bikes Challenge
  • Remix Contest
    Remix Contest
6 Discussions
davethewoodworker
davethewoodworker
Answer 2 years ago
what was you going to download?
WOmadeOD
WOmadeOD
2 years ago
lucky cat
MarioL111
MarioL111
2 years ago
Awesome!
