Phone Controller Arduino
Introduction: Phone Controller Arduino
This phone controller can help you to prevent using the phone when you're doing homework or project.
The phone controller I made will make "beeeep" sound after you turn on the switch. I used the ultrasonic sensor to detect if the phone is on the machine or not. When you finish your work, you could just turn off the switch, then you can play with your phone.
Supplies:
Materials:
1. Arduino Leonardo
2. Breadboard
3. Jumper wire
4. Speaker
5. Switch
6. Cardboard
7. Cable
8. Hot glue gun
9. Tape
10. Ultrasonic sensor
Step 1: Step 1: Connect Your Switch to the Breadboard
Step 2: Step 2: Upload Your Codes to Leonardo
void setup()
{ pinMode( 2 , INPUT); digitalWrite( 12 , LOW ); //connect the switch to the breadboard
pinMode( ardublockUltrasonicSensorCodeAutoGeneratedReturnCM( 12 , 11 ) , INPUT); } //the ultrasonic sensor make sure the pgone is on it
void loop() { if (digitalRead( 2 )) { if (digitalRead( ardublockUltrasonicSensorCodeAutoGeneratedReturnCM( 12 , 11 ) )) { tone(8, 1318.0, 1000.0); } } else { } } // the speaker to make beep sound
Step 3: Step 3: Make the Box of It
1. find a cardboard
2. cut it into the size that Arduino board could fit in
3. Tape the jump wire onto the board so it won't be so messy. (inside the box)
4. cut out four holes for the switch, cable and the ultrasonic sensor
5. use the hot glue gun to stick the parts of the box together
Step 4: Step 4: Start the Machine, Get Away From Phone!!
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    2 Discussions
    tytower
    tytower
    1 year ago
    So you did not explain what stops the phone working?
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    It's nice to be able to get rid of distractions like this :)
