Pingpong Ball Launcher
Introduction: Pingpong Ball Launcher
parts list
(5 feet) 1½-inch-diameter PVC pipe(1) 1½-inch socket-to-socket coupling(2) 1½-inch spigot X 1-inch female pipe threaded reducing bushing(2) 1-inch NPT close iron pipe nipples(1) 1-inch in-line sprinkler valve(1) Compressed-air palm-type blowgun (make sure the one you buy has a ¼-inch NPT air connection)(18-inch) 3-inch diameter PVC pipe(1) 3-inch socket-style PVC end cap(1) ¼-inch NPT air-tank valve(1) ¼ inch NPT 0 to 60 psi pressure gauge(1) ¼-inch diameter NPT brass hex or regular nipple, 1 inch long, 1/BlockStrapping tapeVinyl or aluminum tapeping-pong balls
Step 1: Parts
lay out all of your parts and make sure you have all of the parts you need
Step 2: Step 2
Take your cap and drill a 3/8 hole in the center for your step 3 part.
Step 3: Step 3
Take you brass ball vale and you air compressor nipple piece and rap teflon tape around the threads of both and thread and tighten the two together.
Step 4: Step 4
take your cap with the fittings threaded in and tightened and take the (18-inch) 3-inch diameter PVC pipe and glue the two together.
Step 5: Step 5
now take the part from step 4 and now take and dril a 5/16 hole just above the top of the cap into the 3-inch diameter PVC pipe. then take your 60 psi gage and put teflon tape on the threads and screw it into the hole.
Step 6: Step 6
Now take your part you have made from step 5 and now glue the 3" to 1" adapter to the other end. then screw it to the pressure release valve.
Step 7: Step 7
then glue the 1 inch coupler to the 1" barrel.
Step 8: Step 8
let sit over night and then put pressure to it and test for leaks. if any leaks are present take the aluminum tape and rap it around where the leak is.
Step 9: Step 9
test fire
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Metalworking Contest
    • Puzzles Speed Challenge
    2 Discussions
    Masher007
    Masher007
    9 months ago
    I made one with a metal air chamber. We have metal chambers for home made launchers, and sell complete launchers too. JJsporting JJmultilaunchers
    seamster
    seamster
    1 year ago
    Very cool, looks like a lot of fun. I've made a lot of launchers over the years. Always fun!! : )
