Plant Label From Copper Pipes.
Introduction: Plant Label From Copper Pipes.
About: Perpetual prototypist
I made these plant labels from scrap copper pipes.
Copper is said to help the soils and protect plants against snails and slugs.
The construction requires hand tools and a drill.
Obviously, the plants shown here are not beans but strawberries!
Teacher Notes
Step 1: Parts and Tools
12mm (1/2") copper pipe for stalk - 200mm (8") suggested length.
19mm (3/4") copper pipe for top piece where plant name is written upon. 80mm (3") suggested length.
4mm pilot drill bit
10mm - 12mm drill bit ; stone the sharp edges of the drill bit flat so as not to 'snag' the copper pipe when drilling through.
Flat file, round file.
Hacksaw
Deburr tool and/or counter sink to trip burrs off cut pipes.
Vice
Drill - hand or drill press.
Step 2: Cut Copper Pipes to Desired Length.
I chose 80mm (3") length for the top piece, and 200mm (8") for the stalk.
Cut the stalk with a 45 degree angle so it pushes into the ground easier.
I used a hacksaw, but a pipe cutter could also be used.
Step 3: Drill Hole in Top Piece
Measure and mark the mid point of the top piece.
Drill a pilot hole first, then a larger hole. The biggest bit I had was 10mm, so the hole needed filing out to 12mm (1/2") by hand.
Best to use a blunt drill bit as a sharp drill bit can 'grab' the copper as it is cutting through.
Step 4: Insert Stalk Into Top Section and Squash With Vice.
Crush the top section with a vice with the stalk in place. Move the top piece around to squash to completely flatten out the whole piece.
Bend the stalk backwards to provide a desired viewing angle.
File off and sharp edges.
Step 5: Mark With a Sharpie.
Label can be re-used simply by cleaning off any existing marking with cleaning alcohol.
The copper can be made to shine by soaking it in water and a teaspoon of citric acid overnight.
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
