Plastic Cup Sphere Light
1,894
41
12
About: Synth chick for electro-rock band, Former Human Beings
The holidays make for more parties, which bring us more drinks, which means extra plastic cups everywhere! What do you do when you have so many Solo cups? Make a big, beautiful spherical light, I say! This contemporary light is simply made from cups, a string of colourful Christmas lights, a drill, and a stapler. Make sure you rinse and dry your cups if you're upcycling, or else your light will be radiating leftover beer. Wait, you might like that.
Step 1: Gather Your Materials
You will need:
  • 30 or more Solo cups (I used large ones)
  • drill with 11/32" drill bit
  • stringed Christmas lights
  • stapler
*The size of the drill bit may need to be bigger or smaller depending on the size of your Christmas light bulbs. I used a standard set of lights and this was the perfect drill bit size for me.
Step 2: Drill Away
Drill a hole in the center of the bottom of a cup.
Poke a Christmas light through the bottom to make sure it's a good fit. You want it to poke through without it being too loose so they don't slip off. Continue drilling holes in the rest of the cups.
Step 3: Staple It
Staple 2 cups side by side, making sure one of the cup's lip is just over the other cup's.
Now staple another one next to the other, staggering the cup lips again. They should eventually stagger over, under, over, under, et cetera.
Step 4: Staple More
You can make this as big as you like, but since I used massive cups, my lower level was just a crescent made of 8 cups. Start stapling on another level on top of, remembering to stagger the lips.
Go all the way across, stapling the cups to the ones below and the ones to their sides.
Keep going up and across until it starts turning into a ball. You'll start using less cups the higher you get.
Step 5: Add the Lights
When you're happy with your spherical shape, turn it over and begin poking the Christmas light bulbs through the holes. They will stay firmly in place.
It will look better if you don't put the same colour bulbs in side-by-side.
Step 6: Plug It In
Plug in your lights and enjoy the insanely beautiful glow. Better with your main lights off!
    • Pie Contest
      Pie Contest
    • Paper Contest
      Paper Contest
    • Organization Contest
    12 Discussions
    KerryC22
    3 months ago
    attosaKerryC22
    Reply 3 months ago
    Lovely! Thanks for the shopping cart!
    MomoC4
    3 months ago
    A great use of cups and so pretty! I’d like on the lawn
    attosaMomoC4
    Reply 3 months ago
    I say go for it!
    Maladiun57
    3 months ago on Step 6
    I just got a set of lights at the grocery store that flashes in response to sound!
    attosaMaladiun57
    Reply 3 months ago
    At the grocery store?! Luck! I never see that stuff at mine ;) Whatcha gonna play to it?
    attosaMaladiun57
    Reply 3 months ago
    Absolutely! Totally safe for outdoor weather too :)
    EveW12
    3 months ago
    I could see this in all white for a wedding=)
    attosaEveW12
    Reply 3 months ago
    Wonderful twist!
