Playstation 4 VR Headset Simple Wall Mount for Under $10
Introduction: Playstation 4 VR Headset Simple Wall Mount for Under $10
About: I'm a Former manager and im a dad who is always looking for something fun and interesting to do I lost both of my kidneys and is on dialysis(just got a kidney transplant 9/16/18 I’m in recovery now) I am bl...
This is a very quick and easy anyone can do this PlayStation 4 VR wall mount You also can use this to hang headphones off of which I will be doing I’m going to put another one on top of this one
Teacher Notes
Step 1: Things You Will Need
You will need anchors with screws A stud finder A hammer A screwdriver or a drill and a few pieces of foam Some clear tape and four pieces of two sided tape And the main part a shelf mount they are many different kinds wood Metal plastic different styles you can choose Just make sure the VR headset will fit on there you just need to buy one
Step 2: Hanging Up the Wall Mount
Hanging up the wall mount is very easy it’s the same way you would do if you were hanging It up to put a shelf on it except you’re putting it upside down Use the stud finder to find one stud You can use your hammer Screwdriver or drill To put the anchors in the wall Then put the shelf bracket up Most of them just have three screws
Step 3: Add the Foam
This is where you can get a little creative( I’m actually going to update this part I’m going to put small piece of leather over the foam) but for now get a piece of foam just large enough to fit the headset so when it rest on the wall it does not scratch the wall and more importantly it will not scratch the VR headset You could hang it up on the wall many ways I find it easy just to get four pieces of two sided tape one on each corner and hang it Then take another small piece of foam wrap it around the bracket where the VR headset will rest put a piece of clear tape over it to hold it in place
Step 4: Hang the Playstation 4 VR Headset
That is it quick easy inexpensive you can do this for under $10 it depends what kind a shelf bracket you get the one I used cost 2 dollars at Walmart and that was for two of them I had anchors and screws here tape and everything else the foam I used was from something I got from Amazon it had foam in the box I used that but you can buy foam for a few dollars So altogether I really spent 2 dollars And like I said earlier I will be upgrading this I’m going to wrap the foam in leather Thank you hope you enjoyed
Game Life Contest
Game Life Contest
1 Person Made This Project!
  • Toys and Games Challenge
  • Backyard Contest
    Backyard Contest
  • Silly Hats Speed Challenge
