Plywood's Coffee Table
Recently, having finished my CNC WorkBee construction, I decided to make some nitwits. Since I like furniture design, I make a coffee table. I thought it was nice and decided to share it
Teacher Notes
Step 1: Material and Working Software
Coffee table
Dimensions:
510mm X 650mm X 800mm
Material:
1. Plywood class 2: 1 19mm
2.Tempered glass 10mm
3. Wood oill
The model is produced graphically by SOLIDWORKS 2016 Edition,
Developed by CNC WorkBee.
Step 2: Choose Quality Material
It is advisable to choose high quality plywood sheets, as the low quality material has a roughness between layers. Which is why we have a lot of work to do, and not so much beauty.
Also of great importance is the safety of glass. Glass should be selected with tempered glass. It is very resistant to breakage, and if it breaks it into small bricks.
I used 10mm tempered glass, maybe 8mm can be used to lighten the weight.
Step 3: Tools
CNC bits 1/4 and 1/8 for flywood
Sander Bosch 125mm
Sander sandpaper 125mm 60,80, 100,120,150,180,220, 320, 400, 600
and SPINDLE DRUM SANDER
Step 4: Plywood Processing
Consistent use of sander sandpaper should be considered during processing to achieve a smooth and glossy surface. If we do just that, we will see our reflection on plywood's surface
Step 5: Result
Result of long processing
Step 6: Aluminum Disc Glass Table Top Adapter Attach Circle Decoration
After processing, make the Aluminum Disc Glass Table Top Adapter Attach Circle Decoration Fasteners as desired
Step 7: THE END
CNC Contest
This is an entry in the
CNC Contest
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    2 Discussions
    attosa
    14 days ago
    What a gorgeous outcome :)
    seamster
    14 days ago
    This is a neat design, I like it! : )
