Pocked Sized Finger Ballpoint
Introduction: Pocked Sized Finger Ballpoint
About: (love to share) some projects simply translate or modification of an existing project
the advantage of this method is that ballpoint is more economical when taken in a wallet or anywhere
You can use the contents of the ballpoint pen directly with any help available to attach to your finger and use it to write or draw
if you use the contents of a ballpoint pen that is plastic you can cut it as desired to make it shorter
choose this method that you think is comfortable and easy
material :
ballpoint pen refills
ducktape/ rubber band/tissue/ raffia/ pieces of paper/ rope/wire (optional)
Teacher Notes
Step 1: Method 1
adjust the location of the ballpoint pen on your finger according to what you expect to be comfortable to use
Stick the contents of the ballpoint pen with ducktape on your finger
press your thumb on the ballpoint pen
ballpoint pen is ready for use
Step 2: Method 2
wrap the rope so that the ballpoint sticks tightly to your finger
Step 3: Method 3
wrap the rubber band so that the ballpoint sticks tightly to your finger
Step 4: Method 4
wrap the tissue so that the ballpoint pen sticks to your finger
Step 5: Method 5
wrap the wire so that the ballpoint sticks tightly to your finger
Pocket Sized Contest
Be the First to Share
    • Toys and Games Challenge
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
