Pocket Volt Meter
4,195
37
6
Introduction: Pocket Volt Meter
About: I like to build some cool stuf
I have been using a bigger version of this voltmeter for quite some time and it was always very helpful
so when I saw Pocket Sized Contest I said to my self why didn't use this opportunity and share this with you
I made a few design improvements during this process so I am very happy with results
Step 1: Materials and Tools
parts:
tools:
  • soldering iron
  • hot glue gun
  • hot air gun or flame from hob (if you using heat shrink foil)
Step 2: Switch
  • disconnect all wires and find the best position for the switch
  • if you have a good position you can glue switch on the place
  • then connect (+) power to middle pin on the switch
Step 3: Probes
  • connect a wire to crocodile clips and secure it with hot glue
  • then connect black (-) probe to common ground and red (+) probe to pin where was orriginaly yellow or white wire
Step 4: Battery Connector
  • pick a place where you want your voltmeter and cut them to the needed length
(I made this second to sit on the connector so they were werry short)
  • connect the red wire to switch pin and black to common ground
Step 5: Test
  • test it and if everything works you can adjust accuracy if needed with little potentiometer (not every voltmeter have this option)
  • if you are done glue every wire to secure long life and glue the whole potentiometer on its place
  • you can wrap finished voltmeter in heat-shrink foil if you want for better-looking finish
Step 6:
and you are done you can now put your mini voltmeter into your pocket and have it wherever you go ready to use
enjoy :)
Be the First to Share
    • Potato Speed Challenge
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    6 Discussions
    liquidhandwash
    liquidhandwash
    1 year ago
    I really like your project, I teach electronics and I think it will be a great project for my students. I might even try to make it smaller by using button cells and a push button to turn it on.
    nikdo_nic
    nikdo_nic
    Reply 1 year ago
    if you can remove the voltage regulator you can power it directly by 3V without power loses
    then it can run efficiently on button cells
    alby21europa
    alby21europa
    1 year ago
    I made it, today....i simply add the megnetic part from hdd, for use it in diffrents situations...
    nikdo_nic
    nikdo_nic
    Reply 1 year ago
    nice thank you for sharing
    catestseries
    catestseries
    Tip 1 year ago
    Nice explanation
    nikdo_nic
    nikdo_nic
    Reply 1 year ago
    thanks
