Poly 3D Printer
17,018
271
19
About: Poly is a multitool 3D printer that uses open source firmware and software, made in PLA, a totally ecological and compostable material. The concept behind Poly is based on three keywords: open-source, eco-fr...
Poly is a multitool 3D printer with nozzle extruder, laser engraving, a chocolate kit and an additional joint for other tools, all plug and play thanks to a magnetic joint and release mechanism. The movement consists of a classic system with 3 Cartesian axes (1 microstepper for each axis, except for the z in which they are used 2) with sliding obtained by means of threaded bars.
Teacher Notes
Step 1: BOM
In this excel file you will find the list of components needed to assemble a Poly.
Step 2: STL Files
This compressed folder contains all the 3D files in stl format which will be used to 3D print the entire frame. We recommend the use of PLA as a material, a fill of at least 30% and a layer height of 0.24mm ( if you use a nozzle with a 0.4mm hole).
Don't you have a 3D Printer? Do you need the plastic pla kit for assembly? try to go here! https://www.3drap.it/product/poly-full-plastics-kit/
Step 3: Building Video
We have prepared a video with 3D animations, to make the assembly phase as simple as possible. At the top right you will see the components that will be mounted in the various phases. You can not go wrong!
Step 4: Motor Driver Voltage Regulation
This is a fundamental phase of building. The regulation of the motors voltage. The micro-steppers need to be powered with a very low voltage (we are talking about 0.2 volts).
To do this you need a classic multimeter and the 12v power supply to power the MKS BASE electronic board. It must be set on the voltmeter mode (2v scale) and positioned with the positive pole on the trimmer and the negative pole on the USB port of the MKS Base board. It will be necessary to repeat the operation on all the trimmer on the board.
Once the first value has been read, adjusts the tension by turning the trimmer with a cross screw (clockwise to increase and counterclockwise to decrease). Once that the correct voltage is obtained, connect the motors to the board and check that they do not overheat.
Step 5: Wiring
In this pdf document you will find all the electrical connections to do in order to run poly. Be aware of colors and polarity, because you risk of burning everything!
Step 6: Cable Management
These photos will make you immediately realize how the cables must be arranged inside the case.
As you can see, the cables are hidden by a back plate and go through the top cover of the box that contains the electronics.
Step 7: Firmware
We have reached the heart of the project.
Poly works thanks to the incredible work done on the Marlin open source firmware. In this Poly_firmware.rar file you will find the firmware already preconfigured for Poly and that you can load on the MKS Base card using the Arduino ide.
  1. Extract the folder Poly_firmware on Desktop
  2. Download the arduino ide here https://www.arduino.cc/en/Main/Software
  3. If MKS BASE board driver can not be installed automatically, you can download the driver from following link: http://www.osoyoo.com/driver/FAT%20232%20driver.rar
  4. Connect the Mks Base Board to PC and Install the driver
  5. Open Arduino ide, in "tool" menu, select the "com port" and "Arduino / Genuino Mega or Mega 2560" board
  6. In File menu select "open" and seach the marlin.ino file inside the Poly_firmware folder and open it
  7. Press the upload button and wait for completion
Now your Poly is programmed and ready to work!
P.S.: POLY is now on github! >>> https://github.com/poly3dprinter/poly <<<
Step 8: 3D Print
With poly you can print in 3D using a pc connected via usb or a smartphone connected via bluetooth.
First of all you have to start from a 3d file. If you can not draw with a cad 3d we suggest you go to thingiverse.com and download a 3D model already designed in .stl format.
Once you have the stl file, you need a software that converts that file into printer instructions (.gcode). To do this we recommend a free software like Cura, slic3er, Repetier Host etc ..., which will allow you to change many parameters and get good prints.
For convenience in this guide we will show you the main operations to be performed with just one of these softwares: Cura.
  1. Download care here: https://ultimaker.com/en/products/ultimaker-cura-software/download-request/182
  2. Start it and add a "custom printer" like in the picture
  3. Upload your 3D model and scale it if it does not enter the print area
  4. Set the print parameters as in photos and generate the .gcode file
  5. To launch the actual print, download this software: http://kliment.kapsi.fi/printrun/Printrun-win-18Nov2017.zip that will allow you to move the axes manually and send the print file to Poly.It is not necessary to install it. It is a ready-to-use exe.
  6. Open it, select 9600 baud rate and connect by selecting the correct "com port" . Upload the file by clicking on "load file". Once loaded you will see a preview of the movements that will perform poly.
  7. Click on the "print" button and enjoy the show!
If you have followed the guide to the end, you have also installed the HC06 bluetooth sensor.
It allows you to send for print without using PC and cables but simply with your android smartphone. There are many apps in the google market place that are compatible with poly hardware. One of these is 3DFOX.
Download the app here: https://play.google.com/store/apps/details?id=com.fox3d.controller
  1. copy the file to the "3dfox" folder of your smartphone using the integrated file manager.
  2. select it from the app and launch your print in total freedom!
Step 9: Coming Soon...
stay connected ... very soon there will be updates that will allow poly to print chocolate, laser engrave and draw!
Step 10: TEAM
3DRap, a team of innovative young artisans operating with modern creativity. Six guys: four engineering students, a designer, and a web developer. They all come from Italy, living close to each other, and they all share the same passion for design and the same enthusiastic ardor towards innovation.
After months of development and almost 2 years of experience in the field of prototyping and engineering, 3DRap presents “Create”: a simple, flexible and immediate platform whose sole purpose is to materialize your idea in 3D.
Create represents our vision of industry 4.0 and we are convinced that it can be an excellent way to bring new realities to the world of 3D printing, accompanying them throughout the product development cycle, allowing the reduction of costs and time of realization.
    • Indoor Lighting Contest
    • Metal Contest
      Metal Contest
    • Make It Fly Challenge
    19 Discussions
    id11vcna
    1 year ago
    Very nice design. A bit small, but still very interesting.
    MagnusI3
    Question 1 year ago
    where can I find the steperdriver/motor thingy?
    1 answer
    dcurrie2
    Question 1 year ago on Step 10
    3DWRAP, can you make a version of POLY that has a larger build area?
    1 answer
    Poly3DPrinterdcurrie2
    Answer 1 year ago
    It does not make sense. made in pla would be very inaccurate. For that version there are already printers like the Prusa i3 :-)
    OnurhanReyiz
    1 year ago
    It should be really educative for children, and sure is useful irl, thank you for sharing as open source!
    raphan
    1 year ago
    I think there's an error regarding motors voltage.40mV is a quite null value that doesn't come from the manufacturer, could it be a current value instead ?.
    Poly3DPrinterraphan
    Reply 1 year ago
    hi, yes, you're right. The right tension is 0.2v.
    I modified ;-)
    giecuk
    1 year ago
    really nice design, thanks for share it...
    seamster
    1 year ago
    This looks really slick. Nice design idea to have it so easily adaptable to do different things!
