Introduction: Pomegranate+Hibiscus Shampoo
Make your own Anti-Dandruff shampoo in 2 minutes!
Hello friends I am Ajay from Banjarpalaya makerspace
I am showing you how to make Pomegranate+Hibiscus Shampoo. This helps make your hair dandruff free. There are only 5 to steps to make your own. I learnt this technique since it's a practice in our rural Indian village.
Ingredients
Pomegranate leaves
Hibiscus leaves
coconut shell
- stone
Step 1: Pick Leaves
First pick the Pomegranate and Hibiscus leaves
Step 2: Wash the Leaves
Wash the Pomegranate+Hibiscus leaves using any available cleaner river water or tap water.
Step 3: Take the Stone for Grinding the Leaves
You need 2 stones for grinding the Pomegranate+Hibiscus leaves, one has to be small, which you hold in your hand to grind and the other has to have a flat base. Wash both the stones to clean off the dirt.
You can use the mixer grinder if you're indoors.
Step 4: Grind the Pomegranate Leaves
Put the leaves on a bigger piece of rock which has a rough surface and start rubbing the leaves such that they get crushed in between the two stones. You have to put some drops of water in between the grinding procedure.You'll obtain a greenish paste in the end,
Step 5: Grind Hibiscus Leaves
Then grind the Hibiscus leaves like the previous step.
Step 6: Mix the Pomegranate+Hibiscus Grained Paste
Mix the Pomegranate+Hibiscus grained paste in a coconut shell for an authentic look and it's ready to apply.
Step 7: Apply Shampoo to Head
Put the paste on the hair, and evenly spread it.
Step 8: Massage
Massage so that the paste reaches the scalp region.
Survival Contest
