Portable Case With Battery for Raspberry Pi Zero W (EN/FR)
3,619
29
Introduction: Portable Case With Battery for Raspberry Pi Zero W (EN/FR)
About: BioAutomation researcher (it's like Biology but the boring lab manipulations are replaced by robots)
EN
This guide will explain how to create a "Portable computer" with a Raspberry Pi zero, an Iphone battery et some electronics modules
FR
Ce guide explique comment fabriquer un "Ordinateur Portable" avec un Raspberry Pi zero, une batterie d'iphone et quelques modules electroniques
Step 1: Material
Step 2: 3D Printing
EN
Get the 3D files on thingiverse : https://www.thingiverse.com/thing:3201105
I printed the files in clear ABS (https://hobbyking.com/en_us/abs-3d-printer-filamen... ) with a Anet A8 printer.
FR
Téléchargez et imprimez les fichiers sur thingiverse : https://www.thingiverse.com/thing:3201105
J'ai personnellement imprimé les pièces en ABS transparent (https://hobbyking.com/en_us/abs-3d-printer-filamen... ) avec une Anet A8.
Step 3: Soldering
EN
  • Solder the "USB cable" to "the +/- OUT of the Step UP module" (Set the module to 5V BEFORE plugin the Raspberry)
  • Solder the "battery +" to the "battery +" of the charger/protection board
  • Solder the "battery -" to "one pin of the switch"
  • Solder the "other pin of the switch" to "the battery -" of the charger/protection board
  • Finally solder the "+/- OUT of the charger/protection board" to the "+/- IN of the step UP module"
When all the connections are made :
  • Place the battery in the battery case
  • Add the battery cover
  • Secure everything with epoxy resin
FR
  • Soudez le "Cable USB" aux "SORTIES +/- du module Step UP" (Régler le module sur 5V AVANT de le brancher dans le Raspberry pi)
  • Soudez le "+ de la batterie" sur la pin "battery +" du circuit de charge/protection
  • Souder le "- de la batterie" sur "une des pins de l'interrupteur"
  • Soudez "l'autre pin de l'interrupteur" sur la pin "battery -" du circuit de charge/protection
  • Enfin, soudez les pins "+ et - OUT du circuit de charge/protection" sur le "+/- IN du module Step UP"
Une fois toutes les connections effectuées :
  • Placez la batterie dans le boitier
  • Ajoutez le battery cover
  • Fixez le tout a l'aide d'époxy
Step 4: Assembling
EN
Secure all the part with epoxy as shown in the picture
FR
Fixez toutes les pièces comme présenté dans les photos
Step 5: DONE
You can now close the box an do what you want with the Raspberry pi.
Vous pouvez maintenant fermer la boite et faire ce que vous voulez avec le Raspberry pi.
Plastics Contest
Plastics Contest
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
