Potentio Indicator Uses RGB Neopixel
60
someone who likes electronics
In this article I will make a rotation indicator of the potentio meter using RGB Nano pixel ring.
So, how many revolutions made on the potentiometer will be displayed on the RGB ring
Teacher Notes
Step 1: Required Components
the components needed to make it :
  • Arduino Nano v.3
  • RGB RIng NeoPixels
  • Potentiometer
  • Jumper Wire
  • USB mini
  • Project Board
Step 2: Circuit Schema
Assemble all components in accordance with the drawdown scheme above.
Arduino to Potensio & RGB Ring
+5V ==> 3.Potensio & VCC
GND ==> 1.Potensio & GND
A0 ==> 2.Potensio
D12 ==> IN
Step 3: Programming
Copy the code below, and paste it into your sketch
<p>#include <br>#ifdef __AVR__
 #include  // Required for 16 MHz Adafruit Trinket
#endif</p><p>#define PIN 12
#define NUMPIXELS 16 </p><p>Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);</p><p>#define DELAYVAL 10</p><p>void setup() {</p><p> #if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
  clock_prescale_set(clock_div_1);
#endif</p><p>pixels.begin();</p><p>pixels.setBrightness(10);
 Serial.begin(9600);
}</p><p>void loop()
  pixels.clear();
  int val = analogRead(A0);
  val = map(val, 0, 1023, 0, 18);</p><p>
  if(val == 1)
    for(int i=0; i<1; i++)
      pixels.setPixelColor(i, pixels.Color(0, 225, 0));
      delay(10);
  }</p><p> if(val == 2)
    for(int i=0; i<2; i++)
      pixels.setPixelColor(i, pixels.Color(32, 225, 0));
      delay(10);
  }</p><p>  if(val == 3)
    for(int i=0; i<3; i++)
      pixels.setPixelColor(i, pixels.Color(64, 225, 0));
      delay(10);
  }</p><p>  if(val == 4)
    for(int i=0; i<4; i++)
      pixels.setPixelColor(i, pixels.Color(96, 225, 0));
      delay(10);
  }</p><p>  if(val == 5)
    for(int i=0; i<5; i++)
      pixels.setPixelColor(i, pixels.Color(128, 225, 0));
      delay(10);
  }</p><p>  if(val == 6)
    for(int i=0; i<6; i++)
      pixels.setPixelColor(i, pixels.Color(160, 225, 0));
      delay(10);
  }</p><p>  if(val == 7)
    for(int i=0; i<7; i++)
      pixels.setPixelColor(i, pixels.Color(192, 225, 0));
      delay(10);
  }</p><p>  if(val == 8)
    for(int i=0; i<8; i++)
      pixels.setPixelColor(i, pixels.Color(225, 225, 0));
      delay(10);
  }</p><p>  if(val == 9)
    for(int i=0; i<9; i++)
      delay(10);
  }</p><p>  if(val == 10)
    for(int i=0; i<10; i++)
      pixels.setPixelColor(i, pixels.Color(225, 192, 0));
      delay(10);
  }</p><p>  if(val == 11)
    for(int i=0; i<11; i++)
      pixels.setPixelColor(i, pixels.Color(225, 160, 0));
      delay(10);
  }</p><p>  if(val == 12)
    for(int i=0; i<12; i++)
      pixels.setPixelColor(i, pixels.Color(225, 128, 0));
      delay(10);
  }</p><p>  if(val == 13)
    for(int i=0; i<13; i++)
      pixels.setPixelColor(i, pixels.Color(225, 96, 0));
      delay(10);
  }</p><p>  if(val == 14)
    for(int i=0; i<14; i++)
      pixels.setPixelColor(i, pixels.Color(225, 64, 0));
      delay(10);
  }</p><p>  if(val == 15)
    for(int i=0; i<15; i++)
      pixels.setPixelColor(i, pixels.Color(225, 32, 0));
      delay(10);
  }</p><p>  if(val == 16)
    for(int i=0; i<16; i++)
      pixels.setPixelColor(i, pixels.Color(225, 0, 0));
      delay(10);
  }</p><p>  if(val == 17)
    for(int i=0; i<17; i++)
      delay(10);
  }</p><p>  if(val == 18)
    for(int i=0; i<18; i++)
      delay(10);
  pixels.show();
  delay(DELAYVAL);
}</p>
Sketch file can be downloaded below:
Step 4: Result
For results can be seen in the video above.
So every time the potentiometer is rotated, the number and color of the LEDs on the ring will light up according to the number of turns done on the potentiometer.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    3 Discussions
    tytower
    5 weeks ago
    I could not find the "ino" file . Did you attach it?
    Sottongtytower
    Reply 4 weeks ago
    I'm sorry, I forgot to add it.
    now I have added the file. please check
    tytowerSottong
    Reply 4 weeks ago
    Good stuff thanks. Makes sure I don't get copy errors on trying to run the file. Good idea by the way . Can't wait to find a use for it at home here.
