Predator Hunter
About: Crossover creative
This was my first time working with eva foam.
Helmet and body armor: The helmet and back portion was made using foam floor mats and led strips. the rest was made out of 6mm eva foam. For the back, I added two plastic containers, lined them with a plastic pink school folder, and added lights inside to give it a nice glowing effect.
Arm Cannon: The arm cannon was made using a 4in diameter PVC pipe, It was then covered in craft foam. A red light was inserted into the opening for the "laser".. Then led strips were added and covered in silicone tubing . A mini smoke machine made using a water pump and vape pen was attached to a tube that goes into the "laser" portion to give it a smoke effect
Supplies:
PVC pipe
Vape pen
Water pump
6mm eva foam
Led light strip
2.4 power bank
Teacher Notes
Halloween Contest 2019
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
