Introduction: Pressure Switch for Makey Makey
How to build a simple pressure sensitive switch. Use this technique with any project!
Step 1:
Cut two pieces of aluminum foil tape a two pieces of cardboard to the same size.
Step 2:
Attached the aluminum foil tape to the pieces of cardboard.
Step 3:
Cut two thin strips of foam.
Step 4:
Put the two strips of foam on one of pieces of cardboard.
You can use glue for this if you'd like, but it's not necessary since we'll be using a rubber band later on.
Step 5:
Put a rubber band around your button.
Step 6:
Attach an alligator clip from EARTH to one of the cardboard pads, and SPACE or CLICK to the other.
Step 7:
How when you push down on the switch the Makey Makey will send a signal to the computer.
Step 8:
Here's a primer on simple switches from our the Tinker Studio.
Step 9: Extensions (Optional)
Now from here there's lots you can do.
You can measure how much weight your pressure pad can withstand before sending a signal like a kind of scale. You can increase the amount of foam or size of your switch to make a heavier scale!
Or you can make a series of these for a musical hallway, or a DDR pad, or a relay race track.
Whatever you do, post your pictures in the gallery by clicking "Upload Your Work" right here below.
