Prime Cables Bluetooth Speaker Teardown
Introduction: Prime Cables Bluetooth Speaker Teardown
This guide will walk you through the disassembly process of the prime cables Bluetooth speaker. I had to do this fix the solder on volume up/down buttons.
Teacher Notes
Step 1: Grill
Use a dentists pick to take off the grill
Step 2: Remove Screws (Front)
Use a Philips screwdriver to remove all 6 screws (see picture)
Step 3: Remove Screws (Back)
Use the same screwdriver to remove 1 more screw at the back (see picture)
Step 4: Done
follow the steps in reverse to put it back together.
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    audreyobscura
    audreyobscura
    1 year ago
    Thanks for sharing your teardown tips!
