Introduction: Printable LED Lamp
This is a printable LED lamp with WS2812 LEDs. They can be powered via USB, power supply or with an Arduino.
Follow me on Instagram for latest news
https://www.instagram.com/ernie_meets_bert/
Step 1: Parts to Print
Find all parts you need on Thingiverse.
https://www.thingiverse.com/thing:3511731
All parts are printed in PLA. The outer coil should be printed as vase-mode. The only part which needs support is the bottom. Print it in the orientation it is saved as.
Print a case of your desire
1x bottom (needs support)
1x bottom cover
1x inner coil
1x outer coil
1x top (print your preferred part)
1x base_polypanel (for polypanels from MakeAnything)
1x top_polypanel (for polypanels from MakeAnything)
Step 2: Parts You Need (BOM)
Here is the list with all necessary parts for the LED lamp
1x LED strip (I recommend at least 2m)
1x Power Switch
6x M4 x 12mm screws
4x M3 x 6mm screws
Step 3: Base
Attach the power switch and the power plug to the bottom plate (If you want to power the lamp with a power supply). Otherwise you don't need them.
Use two M4 x 12mm flat head screws to mount the inner coil to the base plate.
Step 4: Electronic (LED)
As I wanted to power the lamp with a power supply, I unsoldered the USB cable and soldered the LED receiver to the power connector. Hereby I have a clean body.
Step 5: Done
Use the outer coil as a diffuser for the LEDs and put the top on you prefer.
You can secure the top with four M3 x 6mm screws.
Here you find the parts for the polypanel top
https://www.myminifactory.com/collection/collection-show/Matteo-/PolyPanels
