Printing Colored Text in Python Without Any Module
Introduction: Printing Colored Text in Python Without Any Module
About: A kid with two arms, two legs, a nose, a head and a torso!!!
After my second Instructable was deleted accidentally, I decided to make a new one.
In this one I will show you how to print colored text in python!
Teacher Notes
Step 1: The Codes
Try:
TGREEN =  '\033[32m' # Green Text
print (TGREEN + "This is some green text!")
We see that after the green text is printed, the whole shell changes color!
To combat that can we use this?
TWHITE = '\033[37m'
print (TGREEN + "It doens't reset!" , TWHITE)
NO!!
It turns all the text white...and a different type of 'dull' white if you see it carefully.
If you want to commit your code to GITHUB, then many people using your code may have a customized Python Shell with probably YELLOW or Something as their text/background color!
So the answer is:
ENDC = '\033[m' # reset to the defaults
print (TGREEN + "Das ist es!" , ENDC)
Step 2: Usage
The usage goes like:
\033[code;code;codem  # put 'm' at the last
\033[code;codem  # use semicolon to use more than 1 code
\033[codem
\033[m   # reset
The list of the codes are in the next step.
Step 3: List of Codes
The pictures says it all....though you might find THIS helpful!
I did not mention backgrounds but you can find it HERE.
Just in case you were curious about the code in the intro, here it is.....on GitHub!
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
