Printing Colour Images on to Wood: Making Letter Tiles
106,100
180
39
Introduction: Printing Colour Images on to Wood: Making Letter Tiles
About: Appreciate what you've got, every day will bring something new.
Using wax transfer paper, normally sold for printing images on to t-shirts, you can tranfer images on to most any porus surface. In this instructable I explain how to make a set of tiles similar to scrabble.
Teacher Notes
Step 1: Parts & Tools
You will need to buy
Enough 1/4" plywood to complete the project, higher ply number the better
Wax transfer paper, available from any office supply or craft store. AKA t-shirt transfer paper
Tools
Text editor with options to mirror the output print.
Inkjet printer
Iron, some heavy cotton
Sander
Narrow gauge circular saw or band saw
Overview: A mirror image it printed on to the transfer paper, ironed on to the wood and in this case cut up in to individual tiles.
Step 2: Layout Print
So, this game I'm making is made up of a number of tiles with letters on them.
I've attached an example html file which you should be able to enlarge to fit your paper (A4 or US letter) using the (CTRL) key and '+'. Alternatively import this in to word to manipulate.
Some things to note.
The letter in each row and column should be centered both horizontally and vertically within each cell, which is why I chose html over word.doc.
Leave enough room between each letter for the width of the saw blade and a little. You will also want to chamfer (round off) the edges of each tile
Start with a trial run, print the image on to plain paper and place on the receiving surface to make sure everything is laid out correctly. When you're happy, print to the wax paper.
Step 3: Prepare the Wood
Its very important to prepare the surface of the wood to take the wax. It must be free of any grease, dust etc. I recommend sanding with a fine grit it to score the surface and then washing it with a light detergent/water mix. It MUST be dry before applying the wax.
The surface of the wood should be as smooth as possible. Anywhere the wood does not touch the paper, such as the rough grain, will not take the ink. You can use this to your advantage however, it can give b&w images a weathered look. Doesnt work so well with colour.
The final part of preperation comes just before you are ready to apply the wax paper. As the transfer relies on heat to melt the wax I recommend placing a sheet of cotton over the wood and heating the area as much as possible with an iron. Why the sheet of cotton? an iron directly on the wood will seal and polish the surface, making it harder for the wax to impregnate the wood.
Step 4: Transfer the Image to the Wood
1)Place the paper ink side down. Remeber to print it mirror image.
2)Iron it a little so that it takes to the surface a little, I've only done this with wood so it may work differently with other materials, we will be placing the cotton down in the next step so we want to have the paper stick in place, avoiding it slipping around once we're ironing the cotton.
3)Place the cotton sheet on the paper and place the iron down without sliding it. Apply moderate pressure and repeat until you have covered the entire image.
3.1) Repeat with more and more pressure, you can lift the sheet to check out progress. Once it seems like the paper is completely adhered to the surface you can iron directly on to the paper until it starts to discolour and/or become very shinny and smooth.
Its hard to over-do it but you can cause discolouration of the wood with too much heat and a little bleeding of the ink.
The whole process for an a4 sized transfer is about 10-15 minutes.
Step 5: Remove the Paper
You can lift the paper from the corner while drawing the iron back which helps release the paper from the wood.
If you've found areas that havent transfered completely simply replace the paper and press down with the iron on that area as hard as you can.
You will probably has a waxy residue on various parts of the image. It is easily removed by rubbing with your bare hand or the cloth while its still warm.
Step 6: Cut and Finish the Wood
I use a dremel circular saw attachemnt for detailed work like this. A good band saw is probably a better alternative.
1)cut the the panel in to long strips
2)I built a simple jig to hold the strips as I cut off the individual tiles
3)Sand the edges of the tiles to finish up.
You are done! on to the game
Step 7:
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    39 Discussions
    mrsmerwin
    mrsmerwin
    3 years ago
    I love this idea. I would never have thought of it.
    gusmom
    gusmom
    4 years ago on Introduction
    Love this idea! I have been wanting to make an oversize yardstick, in this case 6 feet long, for a friend to use for tracking her children's height over the years. She can attach it to the wall and mark names and dates beside their height. If they ever move, it is something they can take with them.
    buirv
    buirv
    11 years ago on Introduction
    This is something I've been trying to do for a while. However, I can't find a text editor that will mirror Text properly without making a project of it. MS Word only allows you to mirror a graphic of text. Which text editor did you use?
    paqrat
    paqrat
    Perhaps instead of a text editor you need a graphics program. Paint allows you to insert text. Not sure if Paint will allow you to flip the image but there are others that would.
    Battlespeed
    Battlespeed
    Reply 6 years ago on Introduction
    Late reply, I know (but you know what they say!)...just about every graphics program including Paint has a function to flip an image. Sometimes it's called "mirror".
    jeffeb3
    jeffeb3
    If you can flip the image (and there's not a flip in the properties as Johne99 suggests) then you can hit printscreen, and then paste, and get the text as an image in the word document. Might be cumbersome for large amounts of text, or frequently editing text though.
    holzwurm
    holzwurm
    If you are looking for a good way to print on wood check out my website at www.theholzwurm.com. We directly print on wood up to 1 3/4" thick. I am also a graphic artist so we can take any photo or artwork and print it for you.
    radiorental
    radiorental
    Reply 11 years ago on Introduction
    That is a really good question. Its been a number of years since I've done this but it looks like I must have made an image of it somehow. I'm not sure which file types are going to work best for a simple workflow, but at a guess I'd say you're probably going to have to save the file as a pdf and then import it in to gimp or photoshop. Then flip the image on the vertical axis. Sorry about that.
    johne99
    johne99
    Look at the 'properties' box on the print menue and I have a Mirror Print option box to tick for exactly this problem. No need to export and import.
    Nlarkin
    Nlarkin
    Great tutorial on how to do this at home! If you are looking to get them professionally done, check out InstaThis.com They do a fantastic job of printing on Wood, Metal, and even coasters. You can Connect to your instagram account and print right from there.
    wishinghand
    wishinghand
    Whoa, that looks cool. I wonder how they do that?
    tburch4
    tburch4
    I was wonder what this paper is exactly called and where to find it?...
    radiorental
    radiorental
    yep, as long as you take any paint/varnish off the deck first. You need the ink to soak in to the wood and also, ironing on to paint will cause it to bubble & stuff.
    plpicher
    plpicher
    10 years ago on Step 7
     thanks!
    i was trying with t-shirt transferable sheets but i didn't think about the coton sheet so it was almost imposible to make it right!
    i use it to print my name on my homemade guitars.
    thanks
    abishur
    abishur
    so I just tried it on my own, and the transfer paper keeps leaving a solid wax wall behind and not just the image (which makes varnishing difficult). Is this unavoidable or am I doing something wrong? (or just using low quality transfer paper?)
    radiorental
    radiorental
    you should be able to just rub that waxy coating off without damaging the ink.
    abishur
    abishur
    have you ever tried varnishing the tiles after applying the wax images? Do you know if there would be any problem with doing this?
