Printing Colour Images on to Wood: Place Mats & Coasters
37,964
33
27
Introduction: Printing Colour Images on to Wood: Place Mats & Coasters
About: Appreciate what you've got, every day will bring something new.
Based on the letter tiles instructable you can make any number of objects from key fobs, jigsaw puzzles. Most applications require nothing more than sealing the image with some varnish which also helps the colours stand out.
However in this instructable I show an alternative method of 'printing' an image on to wood and how to apply a cork base to placemats and coasters
Teacher Notes
Step 1: Follow the Letter Tile Instructable
choose your images. I've found that 4 squares per page works out best. Always print a test page first and make sure you mirror the image (aka 'flip horizontal')
Step 2: Cut, Sand, Clean and Varnish
Once the paper is off and you've rubbed of any wax residue, lightly sand the image. Sand the edges and round the corners.
You can wash the wood to remove any dust on the image.
Let it dry and varnish the image and the edges. No need to varnish the bottom.
Step 3: Alternative Method of Placing an Image on to Wood
Print your image out on a laser printer, ink jets may run in the varnish?? Ihavent tried.
Put a coat of varnish on to the wood.
Place the paper on to the wet coat, face up.
Smooth out any air bubbles
Put another coat of varnish on top of the paper.
I'm not a huge fan of this method, I prefer the worn look and feel of the grain with printing directly to the wood. I've seen plenty of people do it this way so maybe someone and chip in with tips on this.
Step 4: Adhere the Corkboard to the Bottom
Fairly straightforward.
Place the wood over the cork and mark the outline with a pencil
Cut
Put a layer of contact cement on the respective faces, let dry for 15 mins
Stick together
Done
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    27 Discussions
    Nlarkin
    Nlarkin
    6 years ago on Introduction
    Great tutorial on how to do this at home! If you are looking to get them professionally done, check out InstaThis.com They do a fantastic job of printing on Wood, Metal, and even coasters. You can Connect to your instagram account and print right from there.
    amandakarl1
    amandakarl1
    12 years ago on Introduction
    I have 70 wooden wine glasses for my Weddign favors and would like to try this to put our names and date on them. Does anyone have any idea how I can do this on a curved surface?
    jgonzalez-2
    jgonzalez-2
    i would try ARMOUR ETCH, "Armour Deluxe Glass Etching Kit" its cheap and and really you can make your own stencils for it as well.
    Najib
    Najib
    12 years ago on Step 2
    Hi, I must have missed something in step 2, I didnt understand how "Once the paper is off and you've rubbed of any wax residue" could you please expand? Thanks
    radiorental
    radiorental
    Reply 12 years ago on Step 2
    Have you tried the step? if you put wax transfer paper on to wood, the wood will only absorb the ink but not the wax, so you have to rub off the excess wax. Cheers - pauric
    thepez
    thepez
    I referred to this and the letter-tile instructable on a project this week. I had to build a carrying case for some items for my church and wanted to make sure I had the church logo printed on the box. I used Avery inkjet paper #3275 but only printed in B/W (can't confirm any running colors). The printed area is on 1/4" luaun plywood and sealed with urethane varnish. Looks great!
    garcar
    garcar
    Reply 12 years ago on Introduction
    Hi "thepez" I'm transfering a family written poem onto a sliced piece of a tree trunk (a wood round). Any, I've sanded and smoothed as much as is possible considering this was made by nature and so there are a few areas that are just a bit lower than others. No problem with the aesthetics, but because the iron is perfectly flat, there are places where the printed "film" just doesn't adhere. It leaves "white/cloudy" areas. one of the "tile" instructions said rub this off. But if you do that, you rub off the ink. The other problem I'm having, that I don't like the look of is what you mentioned regarding your photo where the varnish didn't penetrate the the wax film. But you didn't say if you ever overcame that problem. If you could, I'd love a response as soon as you could. Thahks. Gary
    thepez
    thepez
    I didn't try to overcome the "clear" wax problem on this project because I didn't care about it. I just happened to notice it. I've thought about the problem and I believe the only way to avoid it is to not apply wax in those areas. This means you'd have to cut out those areas prior to heating. Of course, too many cuts and then you have problems holding together your entire transfer.
    Another alternative would be to use a cabinet scraper or something similar to scrape the wax after application. If you're not familiar with a scraper as used in woodworking, it's a flat, steel card on which a burr or raised lip is created on the edges. People often make their own for special profiles or sizes. I think a scraper would be the best solution for those cloudy parts. You can use the edge of a single-edge razor, too - just hold it perpendicular to the surface and pull the edge across the surface.
    Anyway, to avoid the problem altogether, it seems like silkscreen is the next step. Sorry I'm not much help otherwise.
    thepez
    thepez
    Here's the final product. This is after sanding (220, I think) and three coats of spar varnish. In the first picture you can see where the wax prevented the varnish from penetrating the wood. The second is a macro shot showing how well the transfer integrated into the wood. The actual transfer size was a full 8.5" by 11" sheet. The logo and text were prepared in Photoshop.
    scott m.
    scott m.
    13 years ago
    Help, using lazertran inkjet on a canon i9900 mac platform and on darker colors I am getting color bleed. Does anyone know how to solve this problem? thanks, Scott
    sladeburns
    sladeburns
    13 years ago
    Great project. I had some T-shirt transfer paper that I got at a dollar store a while ago and had to try it. I also had some birdseye maple veneer from a lamp project that never realized. I took the image into Photoshop and applied the "photocopy" filter to it. I think it turned out pretty cool and i am excited enough to restart the lamp project and add this technique to it. Thanks. : )
    radiorental
    radiorental
    Reply 13 years ago
    cool! please post the project when you are finished
    radiorental
    radiorental
    Reply 13 years ago
    photoshop filters are a really good idea here... will cover up and untransfered ink mistakes. Thanks!
    divisiongoddi
    divisiongoddi
    13 years ago
    i've transferred images to cloth in much the same way.
    A low cost alternative to the transfer paper is ironing a sheet of clean paper onto freezer paper.
    Put the stiffened sheet of paper with freezer paper through your printer.
    http://www.art-e-zine.co.uk/imagefabric.html
    this link has more info on how to use the freezer paper.
    I used a laser printer and didn't have a problem with the paper or ink transferring.
    radiorental
    radiorental
    Reply 13 years ago
    I've heard a lot about freezer paper, time I bought some.
    penguin
    penguin
    13 years ago
    Lazertran is another transfer paper that would be great for a project like this. Ceramics and metal too.
    radiorental
    radiorental
    Reply 13 years ago
    wow! this is what I love about instructables. Ordinary wax transfer only works with cloth/wood. Lazertran, while a little more expensive works on metal!?!?! effing cool - thanks
    penguin
    penguin
    Reply 13 years ago
    you're welcome. i can't wait to see what cool projects you'll make with it
