Programming ESP8266 ESP-12
Introduction: Programming ESP8266 ESP-12
After so many tries and googling how to upload program to ESP-12
I would like to share my wasted time, I was lucky that my board still working after many wrong tries
Teacher Notes
Step 1: Programming Mode
To upload a sketch via Arduino IDE, Connect as the picture above!
Don't forget resistors you can use from 6.4K to 20K (10K recommended)
Step 2: Normal Use Mode (after Upload)
You can back to normal boot by disconnect pin GPIO0 from GND
also, you can disconnect GPIO2 (optional) but DON'T remove GPIO15 (always pulled down), also don't remove EN pin ( always pulled up)
Good luck
Be the First to Share
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
