Project F.A.N
39
Introduction: Project F.A.N
This instructable was created in fulfillment of the project requirement of the Makecourse at the University of South Florida (www.makecourse.com)
Welcome to Project F.A.N a combination of 3D printed parts, some electronic components, and a little code to allowing you to create your very own desk fan from scratch. The fan is able to turn on/off, oscillate, and output the current room temperature via a temperature sensor onto an LCD screen.
Supplies:
1x Arduino
2x Bread Board
1x 9 volt battery
1x DC Motor
1x DP Switch
1x LCD screen
3x 10k Ohm Resistor
1x Diode
1x Temperature Sensor
1x NPN Transistor
Jumper cables
Teacher Notes
Step 1: Step 1: Setup
The system utilizes two breadboards to allow for the DP switch controlling the fan to be place externally on the base. Also note for the LCD screen i used the SDA and SCL pins paired with the wire header file in order for it to be fully functioning while reducing the number of cables.
The temperature sensor is connected to analog 0 allowing us to read the values that are being input.
The servo is connected to pin 9 allowing us to send the signals oscillating the servo motor.
The Dc motor is attached to pin 12 allowing for us to turn on and off the fan.
The LCD screen uses Analog A4 and A5 to the SDA and SCL pins on the back of the LCD.
Finally the DP switch is connected to pins 2 and 5 allowing us to toggle the functions.
Also very important the DC motor is connected to the transistor and diode to to modify the current running through the motor.
Step 2: Step 2: the Code
//First we include all the necessary libraries allowing us to use our lcd screen and servo
#include
#include
#include //we call to action the servo using the commands from the servo libraryServo myservo;//we set our variables setting ThermPin to analog 0int ThermPin = A0;
int temp;// These variables are going to allow us to set the servo positions
int pos = 0;
int pos2 = 45;
// These pins are for reading the DP Switchconst int buttonPin1 = 2;
const int buttonPin4 = 5;
int buttonState1 = 0;
int buttonState4 = 0;
//setting up our motor to a pwm pin
int motorPin = 12;
//setting up the layout of the LCD screen
LiquidCrystal_I2C lcd(0x27, 16,2);
void setup() {
// First we serial begin and initiate our screen lighting it up
Serial.begin(9600);
lcd.init();
lcd.backlight();
// we use servo commands to pair the servo to pin 9
myservo.attach(9);
// we setup the two buttons as inputs and the motor pin as an output
pinMode(buttonPin1, INPUT_PULLUP);
pinMode(buttonPin4, INPUT_PULLUP);
pinMode (motorPin, OUTPUT);
void loop() {
// We first read the input value from our temperature sensor
temp = analogRead(ThermPin);
// We then use a conversion factor converting the value to degree Fahrenheit
temp = temp * 0.48828125;
//Here we are printing to our LCD screen
lcd.setCursor(0,1);
lcd.print("Temp: ");
lcd.print(temp);
lcd.print(" *F ");
lcd.setCursor(0,0);
lcd.print("PROJECT F.A.N");
//we read if the switches are enabled
buttonState1 = digitalRead(buttonPin1);
buttonState4 = digitalRead(buttonPin4);
//if switch 4 is enabled the motor turns on
if(buttonState4 == HIGH){ digitalWrite(motorPin, HIGH);
delay(1000);
digitalWrite(motorPin, LOW);
//if not the motor stays off
else {
// If switch 1 is enabled the Oscillation begins
if (buttonState1 == HIGH) {
//The oscilattion turns the servo from 0 to 90 degrees and then returns
for (pos = 0; pos <= 90; pos += 1) {
myservo.write(pos);
delay(20);
for (pos = 90; pos >= 0; pos -= 1) {
myservo.write(pos); delay(20);
//if switch is disabled the servo returns to 45 degrees, a middle neutral position
} else {
myservo.write(pos2); delay(50);
Step 3: Step 3: 3D Printed Components
I will link the designed parts, Scale as necessary for your desired fan parts. I would also suggest using supports for the creation of the fan blade as its fairly thin.
Step 4: Step 4: Create
Good luck creating this project, below is a video showcasing my creation and its features for those interested.
For any questions you can contact me at
Thehenrypool@gmail.com
Enjoy Building!
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
