Project Narrowbot
Introduction: Project Narrowbot
About: K day gaming :- This is where you work on your dreams
Hey guys , your K day gamer here ! In this instructable page , I am going to show you how I made my obstacle avoiding robot (The Narrowbot)...... So , let's get started !
Step 1: Gather the Components
You will need the following components to build this ROBOT :
1. Arduino uno
2. Prototyping shield for Arduino uno (optional)
3. Mini bread board ( not required if you have prototyping shield )
4. HC-SR04 Ultrasonic sensor
5. L293d motor driver ic
6. 2 × breadboards
7. Jumper wires
8. An LED
9. Geared motors and wheels
10. 2 × 104 pf capacitors
11. A soldering iron with solder wire and
12 . A caster wheel
13. 2 × 9v batteries with clips ( make sure you have a clip for Arduino and another for breadboard )
Step 2: Make Your Chassis
To make the chassis for my Narrowbot , I am going to use 2 breadboards so that I can make my motor driving circuit on the breadboard itself ! To make my chassis ,
1. Ijoined the two breadboards to make a base for my robot .......
2. I soldered 104 pf capacitors and jumper wires to the motors ,
3. glued the motors to the breadboard base ......and
4. Then I glued caster wheel to the Bottom of the base
5. I plugged the wheels to the motors and now , the chassis is done !
Step 3: Time for Electronics !
# For the electronics , I am using 2 9 volt batteries as power supplies for Arduino and motors !
# Don't worry that Arduino uses only 5 volts , it has a voltage regulator which converts the 9 volt input into 5 volt stable output .....
# I plugged the prototyping shield into Arduino for HC-SR04 ULTRASONIC SENSOR to rest freely on top .
# I the connected it's vcc and ground pins to 5 volts and ground pins on the prototyping shield respectedly .
# Then , I connected it's trig and echo pins to Arduino's digital pins 9 and 10 respectively.
# HC-SR04 connections are done .
# Now let's head to l293d connections !
# see the pin diagram above for reference .
# I plugged in the l293d ic to the breadboard base and made the connections as follows :
# I've connected grounds pins 4 , 5 , 12 , 13 to ground of the Arduino .
# Before I connected the power supply of the motors' to the IC , I added a switch so that it can save power .
# Then , I connected vcc pin of ic ( pin 16 ) to vcc of Arduino and vss pin of ic ( pin 8 ) to 9 volts power supply.
# I then connected the ground of the motors' power supply to ground line in the breadboard.
# I connected the input pins 2,7,10 and 15 of the ic to Arduino's digital pins 2,3,4 and 5 respectively.
# I connected the enable pins 1 and 9 to Arduino's digital pins 5 and 6 respectively.
# Then , I connected the wires from the first motor to pins 3 and 6 of the ic and the wires from the second motor to pins 11 and 14 of the ic.
# just to know if it works or not , I connected an LED to digital pin 13 and ground of the Arduino .
# yay , motor driving circuit is done and now , our whole circuit is complete.
Step 4: Let's Start Coding !
Down below is the code which was used to program the robot ! You may make a few changes to it or just copy it and paste it in the Arduino editor .if the code doesn't work , try using a different code from online and make a few changes if you want or please comment down below about the errors that showed up in your Arduino software so that I can find a code which may work for you !
Code :
const int trigPin = 9;
const int echoPin = 10;
constint in1 = 2;
const int in2 = 3;
const int in3 = 4;
const int in4 = 5;
Int LED = 13;
void setup() {
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode (in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
long duration, distance;
void loop() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration= pulseIn(echoPin, HIGH);
distance= duration/58.2;
if(distance<30) {
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
digitalWrite(LED, HIGH);
delay(1200);
else {
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
digitalWrite(LED, LOW);
delay(0);
Make it Move Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    2 Discussions
    udaykarthikeya77
    udaykarthikeya77
    Reply 2 years ago
    Thank you so much !
