Proximity Measurement
In this tutorial I am going to explain about the measuring the proximity of a device and publishing the values into the Thingsai,io cloud platform by using hall sensor and esp32 development board.
A Hall effect sensor is a device that is used to measure the magnitude of a magnetic field. Its output voltage is directly proportional to the magnetic field strength through it. Hall effect sensors are used for proximity sensing, positioning, speed detection, and current sensing applications.
Teacher Notes
Step 1: COMPONENTS
Hardware Components:
1. Hall Sensor
2. esp32 development board
3. Jumper wires
Software Components:
1. Arduino IDE
2. ThingsIO.AI
Step 2: CONNECTIONS:
Hall sensor----------------------esp32
Aout------------------------------vp
Gnd-----------------------------Gnd
Vcc------------------------------3V3
Step 3: CODING:
#include <WiFi.h><br>
#include <WiFiMulti.h>
#include <WiFiClientSecure.h>
int count=0,i,m,j,k;
int measurement;
int outputpin= A0;//ds18b20
//////////////////////////////////////// ALL DECLARATIONS
for CLOUD //////////////////////////////
const char* host = "api.thingsai.io";                                 // OR host =
devapi2.thethingscloud.com
const char* post_url = "/devices/deviceData";       // OR
/api/v2/thingscloud2/_table/data_ac
const char* time_server =
"baas.thethingscloud.com";
//this is to convert timestamp
const int httpPort = 80;
const int httpsPort = 443;
const char*  server =
"api.thingsai.io";  // Server
URL
char timestamp[10];
WiFiMulti WiFiMulti;
// Use WiFiClient class to create TCP connections
   WiFiClient client;
/////////////////////////////////////// TIMESTAMP
CALCULATION function///////////////////////////////////////
int GiveMeTimestamp()
  unsigned long
timeout = millis();
 // WiFiClient client;
  while
(client.available() == 0)
    if (millis() -
timeout > 50000)
      client.stop();
      return 0;
while (client.available())
        String line =
client.readStringUntil('\r');
//indexOf() is a funtion to search for smthng , it returns -1 if not
found
        int pos =
line.indexOf("\"timestamp\"");                       //search for
"\"timestamp\"" from beginning of response got and copy all
data after that , it'll be your timestamp
        if (pos >=
0)
          int j = 0;
for(j=0;j<10;j++)
timestamp[j] = line[pos + 12 + j];
void setup()
Serial.begin(115200);
    delay(10);
    // We start by
connecting to a WiFi network
    WiFiMulti.addAP("wifi_name",
"wifi_password");
    Serial.println();
    Serial.println();
Serial.print("Wait for WiFi... ");
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.print(".");
        delay(500);
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
    Serial.println(WiFi.localIP());
    delay(500);
void loop()
  int analogValue =
analogRead(outputpin);
/////////////////////////////////////// SEND THE QUERY AND
RECEIVE THE RESPONSE///////////////////////
      int measurement
= 0;
    measurement =
hallRead();
Serial.print("Hall sensor measurement: ");
Serial.println(measurement);
    delay(1000);
Serial.print("connecting to ");
Serial.println(host);                          //defined upside :- host
= devapi2.thethingscloud.com or 139.59.26.117
///////////////////////////////////// TIMESTAMP CODE SNIPPET
Serial.println("inside get timestamp\n");
  if
(!client.connect(time_server, httpPort))
    return;
client.println("GET /api/timestamp HTTP/1.1");                            //Whats this part
doing, i didnt get
client.println("Host: baas.thethingscloud.com");
client.println("Cache-Control: no-cache");
client.println("Postman-Token:
ea3c18c6-09ba-d049-ccf3-369a22a284b8");
  client.println();
GiveMeTimestamp();                        //it'll call the function
which will get the timestamp response from the server
Serial.println("timestamp receieved");
Serial.println(timestamp);
Serial.println("inside ThingsCloudPost");
  String PostValue =
"{\"device_id\":
61121696007 , \"slave_id\": 2";
        PostValue =
PostValue + ",\"dts\":" +timestamp;
   PostValue =
PostValue +",\"data\":{\"proximity\":" +
measurement +"}"+"}";
Serial.println(PostValue);
/* create an instance of WiFiClientSecure */
WiFiClientSecure client;
Serial.println("Connect to server via port 443");
    if
(!client.connect(server, 443)){
Serial.println("Connection failed!");
    } else {
Serial.println("Connected to server!");
        /* create HTTP
request */
        client.println("POST
/devices/deviceData HTTP/1.1");
client.println("Host: api.thingsai.io");
//client.println("Connection: close");
client.println("Content-Type: application/json");
client.println("cache-control: no-cache");
        client.println("Authorization:
Bearer
eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.IjVhMzBkZDFkN2QwYjNhNGQzODkwYzQ4OSI.kaY6OMj5cYlWNqC2PNTkXs9PKy6_m9tdW5AG7ajfVlY");
client.print("Content-Length: ");
client.println(PostValue.length());
        client.println();
client.println(PostValue);
//////////////////////////////////POSTING the data on to the
cloud is done and now get the response form cloud server//////////////////
 Serial.print("Waiting for response
        while
(!client.available()){
            delay(50);
Serial.print(".");
        /* if data is
available then receive and print to Terminal */
        while
(client.available()) {
            char c =
client.read();
Serial.write(c);
/* if the server disconnected, stop the client */
        if
(!client.connected()) {
Serial.println();
Serial.println("Server disconnected");
client.stop();
Serial.println("//////////////////////    THE END
delay(3000);
Step 4: RESULT:
The values which are read from the sensor are being sent to the IOT cloud successfully and the graph is being created as proximity vs time. With this the working of the sensor is analysed and used according to the required areas of application.
Step 5: Complete Tutorial:
This is the complete project for measuring the proximity of a device by using hall sensor esp32 and thingsai.io cloud platform. Thank you
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
