Pruning Shears Extension
Introduction: Pruning Shears Extension
Attach a pruning shear to an existing telescopic pole.
Teacher Notes
Step 1: Adaptor
I needed an extension for my pruning shears. As I already had a telescopic pole for window cleaning, I thought of using this as a base. The pole has two spring-loaded pins to keep the tool in place.
I took a block of wood and drilled a hole matching the thinnest end of the pole.
Drilled two holes for the locking and recessed them with a knife to be able to push the locking pins in completely
Screwed two eyes in the adaptor and one eye in the handle of the shear to act as a 1:2 reduction.
Jam the other handle of the shear in the large hole.
Fit a piece of rope.
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
