Push-up Arduino
That's a simple push-up meter
You need an Arduino, HC-SR04 and creativity for how to attach to your body
Teacher Notes
Step 1: Connections
Trig pin is on 13
Echo pin is on 12
Vcc = 5v
Gnd = gnd
Step 2:
Step 3:
#define trigPin 13
#define echoPin 12
int i;
void setup() {
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
void loop() {
long duration, distance;
digitalWrite(trigPin, LOW); // Added this line
delayMicroseconds(2); // Added this line
digitalWrite(trigPin, HIGH);
// delayMicroseconds(1000); - Removed this line
delayMicroseconds(10); // Added this line
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance >= 40 || distance <= 0){
//Serial.print("Out of range");
(distance = i);
(i++); //With every "out of range" there is +1 push up
Serial.print("/////" );
Serial.println(i);
delay(1000);
Step 4: Output
When is going to "out of range" there is a one more push - up!
Everything is in the code
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
