Quadrifilar Helix Antenna 2 4GHz
In this video I give you my version of the Quadrifilar helical Antenna for 2.4GHz. The antenna is capable of much higher gain than a cloverleaf antenna, so should give much more range.
Teacher Notes
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    4 Discussions
    connie46
    3 years ago
    there is no video showing up so where is it?:(
    allenlorenz1
    2 years ago
    give a weblink or info for the semi rigid coax you used. Also didn't you need to scape to get the braid on the bottom connection ?
    mcauserallenlorenz1
    Reply 2 years ago
    The semi rigid coax is RG402, which you can find for a few dollars on eBay. I've found it's cost effective to buy 50cm cables with RP-SMA Male connectors each end, then cut the cable in half for two antennas. The outer braid is conductive.
