Quick Shelter/fort
This fort is super easy and quick to make. All you need is the supplies from the woods and some sort of tie such as a bungee cord, shoelace, rope, or string. It can be a great family afternoon project or a great project for your kids! Kids will not have much trouble building this by themselves but they will learn about teamwork, tension. hard work, and other things!
Teacher Notes
Step 1: Gather
Very first find a clearing to place your fort.
Then gather long sturdy sticks and lay them in a pile all parallel.
Do not use flimsy, brittle, or short sticks.
It is best if you break or chop off large branches on the sticks to prevent tangling between them later.
Step 2: Tie It Together
Now deside what side you want to be the bottom. If one side has mostaly wider parts of the sticks then it should be the base. You want the base to be mostaly level. The top does not need to be level at all.
Now find where the shortest stick reaches to at the top. If it is much much lower than the other sticks just take it out of the pile or push it up a bit so it is not so much of an outlier. Once you find the shortest stick that is reasonably close to the others you should go down towards the base about two-four inches and tie all the sticks together very tightly. You can use anything you can tie with to tie.
Step 3: Stand and Begin Basic Structure
Stand this up now with the tie upwards and slowly pull sticks outward widening the structure. After a while pick any stick and turn it, winding it up increasing the tension so the sticks do not slip around.
Continue pulling the sticks outward, the top of the structure will lower but it will also become wider.
Repeat this until the size is how you like it.
Step 4: Walls
Now you can rest large or small, sturdy or weak sticks all over the extierior of the structure. These will be the walls so you can add as many as you like.
To increase “life” of your structure’s walls you can put sturdy sticks diagonal to each other over the walls and planted ion the ground.
You could make thick walls or walls with spotty holes it really depends on what you like. I wanted mine to be quick and I might strengthen it later but I just put sticks of all sizes placed withought attention to detail.
Step 5: Optional Decoration
you could layer the ground with pine needles or ferns if you wanted but I just went with a dirt base. I put string lights around the exterior and placed the battery pack on top so to cover it I did the following.
Gather ferns or large leaves and tie the stems together with a string. Put your cluster on top and spread out the ferns.
And you are done.
Step 6: Enjoy
Now you can chill in your fort, it looks really cool but it is also pretty campflouged. You can put a tin in there to store tools or anything you want. Have fun!
Tiny Home Contest
Tiny Home Contest
    • Make It Fly Challenge
    • Stone Concrete and Cement Contest
    • Indoor Lighting Contest
    8 Discussions
    Tura Street
    10 months ago
    You should put a tarp on the outside of the shelter to protect from rain and other things. Looks great. Welcome to instructables.
    krf
    11 months ago on Step 6
    I might suggest that instead of lashing the whole bundle of sticks together, you just lash 3 to make a tripod. The other sticks can then be added to the framework one at a time. That is how you set up the framework for a teepee. See https://www.wikihow.com/Make-a-Teepee
    for a reference
    MooseForestkrf
    Reply 10 months ago
    Thankyou very much! I definitely agree and appreciate the advice! I actually did make a version like this and it is very strong!
    maxman
    11 months ago
    Very nice. Thanks for sharing.
    SquishyPickleRat
    11 months ago
    I like how sturdy but quick it is, really cool.
    MooseForest
    12 months ago
    My sister and I made this together and we hope you love it!
    If you like this please take a moment to vote for our project, we sincerely appreciate every vote so very much! We really want to win one of the places in this competition but wish luck to everyone who enters! Thankyou, have a great day!
    MooseForestPenolopy Bulnick
    Reply 12 months ago
    Thank you very much for the kind words Penolopy! I am very glad you like it!
