RC Generators
Introduction: RC Generators
About: weeeeee wooooo
In this build we will show you how to make a generator with an RC motor.
Teacher Notes
Step 1: The Base of the Build
You will need a piece of cardboard for the base. the recommend size is 7x7 inches.
Step 2: Motors
The preferably size motor is a 220 any thing smaller won't work
Step 3: Wire
The wire is to turn the drive shaft on the motor. Number 24 or 30 wire will do.
Step 4: Light Bulb
the light you will need is a 1.5 volt 25 mA for generator
Step 5: Last Step to Make the Generator
last but not least wrap the wire counter clock wise of the drive shaft of the motor.
Step 6: To Power the Light
Connect the light to the two little tabs on the back make sure to twist the light wires around the tabs
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Arduino Contest 2020
    4 Discussions
    randofo
    randofo
    1 year ago
    How does the generator work? What can you do with it? Does it produce a lot of electricity?
    ManLy Manson
    ManLy Manson
    Reply 1 year ago
    randofo the generator only only works for a few seconds its not a longer lasting generator in is just ment to be a little fun DIY for people to do.
    ManLy Manson
    ManLy Manson
    1 year ago
    are the stick really need tho or can you just put it on cardboard but you guys made a very good generator.
    ManLy Manson
    ManLy Manson
    1 year ago on Step 6
    I made the Generator very easyly the instructions were very simple we made in 15 min.
