REMINDER BOXY
Introduction: REMINDER BOXY
THIS ISN"T A NORMAL BOX.
Step 1: Introduction:
This is not a normal box. REMINDER BOXY is a box that can remind you when your things is too many, it’s time for cleaning. There are 2 different sound and distance: The first sound shows up when things are 10cm long to the top, with a beep for every 1 second. The second sound shows up when things are 5cm long to the top, with two different sound for every 0.5 second.
Step 2: LIST OF THE MATERIAL:
STEP 2.1 Arduino:
- Arduino board (suggest: Arduino Leonardo, but Arduino UNO is fine)
- Breadboard
- Speaker
- Ultrasonic sensor (suggest: HC-SR04)
- LCD board (12C)
- Power bank and USB
- Jumper wires (12 are enough)
STEP 2.2 Box:
- Empty box
- Painting tools (decorate the box)
- Paper board (to make a cover for arduino)
- Box cutter
Step 3: HOW TO MAKE IT/ Arduino:
Step 4: HOW TO MAKE IT/ Box:
1. Find a empty box, decorate it if you want.
2. Use box cutter to cut the hole for ultrasonic sensor on the top of the box (* make sure the position is accurate)
3: Cut a whole for ultrasonic sensor’s jumper wire on the side of the box (* a small whole is okay)
Step 5: Box COVER:
4. Put the arduino board inside the box
5. Use paper board to make a small cover for the arduino board
6. Cut a whole on the side of the paper board (* make sure jumper wires can go through it)
7. Combine the cover and arduino board (* make sure you cover arduino)
Step 6: FINAL STEP of the Box:
8. Use power bank and USB to connect arduino
9. Finish! Now you can put things! (* the cover can also put things on it)
Step 7: CODE:
<p>#include <Wire.h><br>#include <LiquidCrystal_I2C.h>
#define trigPin 10
#define echoPin 12
LiquidCrystal_I2C lcd_I2C_27(0x27,16,2);
void setup() {
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
void loop() {
float duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration / 2) * 0.0344;
if (distance >= 400 || distance <= 2){
lcd_I2C_27.print("Out of range");
delay(250);
if (distance <= 5){ //5cm distance, will shows up 2 different sound for every 0.5 sec
tone(13, 800.0, 100.0);
delay (50);
tone(13, 650.0, 100.0);
delay (50);
tone(13, 500.0, 100.0);
delay (50);
}else if(distance <= 10){ //10cm distance, will shows up a beep for every 1 sec
tone(13, 330.0, 100.0); delay (1000); } else { lcd_I2C_27.print(distance); lcd_I2C_27.print(" cm"); delay(250); } delay(250); lcd_I2C_27.clear(); }</p>
Step 8: TEST IT!
IoT Challenge
IoT Challenge
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    Thanks for sharing! Looks like a fun project :)
