REPAIR: Chinese Spindle 0.8kW Fried Connector
Introduction: REPAIR: Chinese Spindle 0.8kW Fried Connector
About: Target 1000 subscribers. Please Subscribe to my Chanel to help me get the next level! Youtube chanel: https://www.youtube.com/user/laranjas3
Hello guys,
There are lots of people using this Chinese spindles for homemade routers and CNC's:
-0.8kW (Ebay example)
-1.5kW (Ebay example)
-2.2kW (Ebay example)
This instructable was made during a repair of an chinese 0.8kW spindle, the problem was a fried connector from one of the phases.
How it was detected:
-Spindle started to loose power
-Smell like fried electronic/plastic
-Sparks on motor connector
Necessary tools:
-Multimeter (Ebay example)
-Umbrak tools (Ebay example)
-Soldering iron (Ebay example)
-Steel file (Ebay example)
Necessary material:
-Soldering wire (Ebay example)
-3 pin conector female (Ebay example)
-3 pin connector male (Ebay example)
Step 1: Remove the Spindle Cap
To remove the spindle Cap is necessary to:
-Turn off your VFD, assure that the spindle is fully disconnected from the electricity
-Disconnect electric harness from the spindle
-Remove the 4 screws on top of the spindle.
-Remove the Cap gently, remember that the cables are still connected to that. You don't want to rip a cable from your spindle coils.
Step 2: Remove Connector From Spindle Cap
To remove the connector from spindle Cap is necessary to:
-Hold the connector from outside
-Unscrew the nut from the inside
-Cut the electric cables near to the connector
Step 3: Prepare the Spindle Cap for the New Connector
In my case I used an old ATC IEC C14 female connector (like this) , since I had to repair the spindle in the same day it broke. I recommend you to choose the connector based on max current and voltage allowed by the connector and space available to install it on the spindle Cap.
Check the Current on each wire(3 phases AC) for your spindle:
https://www.rapidtables.com/calc/electric/kW_to_Amp_Calculator.html
How to install the connector on the spindle Cap:
-Fix the Spindle Cap on a vice or other way possible
-Choose the Connector position based on available space, take in consideration power cables, water cooling connectors, space from cap to the spindle coils
-Mark the Spindle Cap with the target hole for the connector
-Open a hole with same geometry of your connector, tight as possible, with a steel file
Step 4: Fix the Connector to the Spindle Cap
***If your connector is tightened with a nut, you could skip this step.
To assure that you don't get particles or liquids inside of the Spindle in better to apply some insulation.
How to Insulate and fix your connector:
-Apply some high temperature silicone (or other fixation glue like Epoxy) around the connector and gently spread it with your finger.
-Apply, on the bottom side, Loctite to fix the connector to the Spindle Cap.
Step 5: Soldering the Connector to Spindle Coils
How to solder your connector:
-Strip the 3 Spindle coils wires that will connect to the new connector
-Cut 1 heat shrink sleeve to each wire, the size must be appropriated to you have space to soldering the wires without apply heat on the sleeve(otherwise you will not be able to put the sleeve on the right place after soldering)
-Insert the wires on the connector to prepare the soldering
-Use a soldering iron to apply heat to the soldering wire to solder the wire to the connector
Step 6: Close the Spindle With Spindle Cap
After all the connections are properly soldered it's time to insert the Cap back to the Spindle.
How to do it:
-If you have a water cooled Spindle, is better to apply some silicone between the Spindle and the Cap round the water circuit hole. Be careful to don't get the water circuit blocked with silicone!
-Insert the Cap gently on the Spindle, assure the water cooling holes are aligned
-Apply torque to the screws
-With a small wire try to remove the excess of silicone from the inside of water circuit
-Test if the water cooling system is not blocked with air or water passing thru it.
Step 7: Solder the New Connector for the Cable From the VFD
I just used a connector from an old cord, the best would be to use an appropriated new connector.
-Strip the wires from VFD and spindle Connector
-Join the correspondent wire together
Step 8: Test the Spindle
Before start using your spindle make some tests:
-Check the continuity between phases with a multimeter
-Check is the each phase resistance to evaluate if they are similar.
-The ground pin should be connected to the spindle cap and body to avoid electrical resistance.
If Everything is OK is time to turn the VFD ON and pray for the best!
Step 9: Support TailorTech
I know this is the most inconvenient part, but I'm trying to get my Youtube monetization back.
Don't worry, this will not make me rich but will get me more motivated for new projects.
Target1000 subscribers.
Please Subscribe to my Channel to help me get the next level!
Youtube chanel
What you could expect for next projects:
-Lithium battery tester
-DIY electric motorcycle with VFD (working on it ;) )
Thank you guys!
Fix It! Contest
Fix It! Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Metalworking Contest
    • Maps Challenge
      Maps Challenge
    3 Discussions
    raphan
    raphan
    1 year ago
    This new connector is the european standard used for mains, 240VAC 16A max. !
    Tailortech
    Tailortech
    Reply 1 year ago
    Hello, thanks for the comment. Can you recommend an connector for this application?
    gpavlovsky
    gpavlovsky
    Reply 5 months ago
    Perhaps that was meant just as an FYI? 240 VAC 16A rating is more than enough for your spindle. Although it would be nice to have a locking feature, the same connectors are available in a locking version if you search for IEC C13/C14 locking connector.
    Originally these spindles use a sort of connector which can usually be found using keywords aircraft connector. They (or similar) looking connectors are easily found on eBay (search for e.g. GX16 or GX20 connectors), but I couldn't find an official standard for these. They are available in various number of pins, if you use a 4 pin one you could probably pass the grounding wire inside and make a neater wiring.
    I've heard Harting HAN 3A or 4A connectors used in some 3-phase industrial equipment, those are pretty expensive though.
    Normally VFD manufacturers recommend no interruptions in the cable between VFD and the motor, these spindle seem to be a mass-produced example of ignoring this suggestion.
