RFID Based Pick and Place Robot
Introduction: RFID Based Pick and Place Robot
Since many years people try to replace human work with machines. Machines called robots are faster and more effective than people. The term robotics is practically defined as the study, design and use of robot systems for manufacturing. Robots are generally used to perform unsafe, hazardous, highly repetitive, and unpleasant tasks. They have many different functions such as material handling, assembly, arc welding, resistance welding and machine tool load and unload functions, painting, spraying, etc. Many elements of robots are built with inspiration from the nature. Construction of the manipulator as the arm of the robot is based on human arm. The robot has the ability to manipulate objects such as pick and place operations. It is also able to function by itself. The development of electronic industry robot system technology has been expanded increasingly. As one such application, the service robot with machine vision capability has been developed recently.
Teacher Notes
Step 1: Components Required
1) RFID Tag
2) RFID Reader
3)Arduino UNO
4) Jumper Wire
5)Servo Motor
6) DC Motor
7) Robotic Arm (https://www.amazon.in/Roinco-Metallic-Mechanical-robotic-Gripper/dp/B07FP28Q5J/ref=sr_1_8?keywords=robotic+ARM&qid=1576065471&sr=8-8)
Step 2: Circuit Diagram
Step 3: Check the Code of Ardiuno and Upload
* All the resources for this project: https://randomnerdtutorials.com/
* Modified by Rui Santos
* Created by FILIPEFLOP
#include
#include
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
void setup()
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
Serial.println("Approximate your card to the reader...");
Serial.println();
void loop()
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.println();
Serial.print("Message : ");
content.toUpperCase();
if (content.substring(1) == "BD 31 15 2B") //change here the UID of the card/cards that you want to give access
Serial.println("Authorized access");
Serial.println();
delay(3000);
else {
Serial.println(" Access denied");
delay(3000);
Step 4: Check the Video
Check the video and assemble as the digram
Assistive Tech Contest
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
