RFID Door Lock Using Arduino
Introduction: RFID Door Lock Using Arduino
Hi guys in this instructables we will learn how to create a door lock with arduino using RFID card & RFID reader.
Since RFID card is used in most of the offices and other secure buildings for door access so i thought we should also build our secure door lock using RFID reader & RFID Card to access the door lock.
Teacher Notes
Step 1: Things You Need
For this instructables we will need following things :
Arduino UNO
EM-18 Reader Module with Tags
Relay 5v
LED
Buzzer
Connecting wire
Resistors
Breadboard
Step 2: Connections
Please follow the shown schmatics and connect everything together.
Step 3: Code
Please copy the following code & upload the code to your arduino Board :
char tag[] ="180088F889E1";
char input[12];
int count = 0;
boolean flag = 0;
void setup()
pinMode(2,OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
Serial.begin(9600);
void loop()
digitalWrite(3,1);
if(Serial.available())
count = 0;
while(Serial.available() && count < 12)
input[count] = Serial.read();
count++;
delay(5);
if(count == 12)
count =0;
flag = 1;
while(count<12 && flag !=0)
if(tag[count]==input[count])
flag = 1;
else
flag= 0;
if(flag == 1)
digitalWrite(2,HIGH);
digitalWrite(3,LOW);
delay(5000);
digitalWrite(2,LOW);
if(flag == 0)
for(int k =0; k<= 10; k++)
digitalWrite(4,HIGH);
Step 4: Project in Action
So after connecting everything together and uploading the code to your arduino. Its finally ready for action so connect the power and when you put your RFID card to your card reader it will give access to the door and if it is another card it will not give access. So have fun making your own door lock with Arduino.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
