RGB STAIRS BACKLIGHT USING ADDRESSABLE DRIVERS.
Introduction: RGB STAIRS BACKLIGHT USING ADDRESSABLE DRIVERS.
About: Just a hobby..
Here is my next project on how to make a stairs backlight. This time i was using RGB strip and addressable drivers.The trick was that only 3 wires cable can be used for controlling the leds. So no mess with wiring at all.
The parts I used:
SRGB controller.
RGB Drivers.
Heat Shrink Butt Connectors
RGB and MONO led strips
Supplies:
www.Firefly-Glow.com
Step 1: Connection
The idea is vary simple. 3 wires are coming from the board : PWR, GND, DATA
All Drivers are powered from PWR and GND lines... The DATA cable goes to the first Driver input,then from Driver output to the second Driver input and so on...
Some different types of pir sensors can be connected to the main board. You can find them on to the attached sketch.
Any Smart Home Relay can be attached as well.Its for controlling day/night mode..
I was trying to solder the wires at the vary beginning, but suddenly found a handy stuff on aliexpress.
This is a Heat Shrink Butt Connectors.So all wiring been done in 10 min. Oh forgot to mention, i did the first trial assembly on my working bench... actually when doing wiring along the stairs steps it will takes some longer time...
Here is a video i found on Youtube about those shrinks. https://youtu.be/7Wh5gM8GM70
Step 2: How It Works.
I have attache some videos.
There are two types of drivers for RGB and MONO led strip.I have checked both of them..
Thank for your attention, if some questions do not hesitate to ask...
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    2 Discussions
    fakrysneg
    fakrysneg
    Question 11 months ago on Step 2
    It’s a adressable rgb led?
    Aivaredze1
    Aivaredze1
    Answer 11 months ago
    No.
