Rabbit Hay Feeder and Litter Box
About: Summer camp assistant director by day, maker all the time. I love making stuff and I have a YouTube channel that shows how I do it. Come check me out :)
I got a just got a rabbit and found out that they like to eat while using the litter box, so I made this! It’s a litter box and hay feeder all in one. It was built around a plastic litter box from Petco to make cleaning it a lot easier.
If you would like to see more you can find me here:
Website: www.theshopclass.org
Instagram: @theshopclassca
Twitter: @theshopclassca
Instructables: @theshopclassca
Supplies:
Materials:
1) Sheet of ½” Plywood, brad nails
6) ¼”x__ round wood dowels
2) 1”x1”x__’ square wood dowels
1) Petco X-Large Litter Box
Tools:
Brad Nailer, Circular Saw, Drill
Teacher Notes
Step 1: Cut
Cut all of the pieces to size and shape using the 3D Model as a guide.
3D Model Link
Password: tscrabbit
Step 2: Assemble the Box
Assemble all of the plywood pieces for the main body using glue and brad nails as seen in the video. Seal any cracks with wood filler or silicone so the hay does not fall through and rot.
Step 3: Bars
Drill ¼” holes in the square dowel far enough apart to let the rabbit access the hay, but close enough together that its head won’t get stuck. This distance varies based on the size of your rabbit. Drill matching holes in the other square dowel.
Step 4: Finish the Bars
Attach the lower square dowel to the body of the box with brad nails and glue. Insert the round dowels into the holes with some glue, and cut them to the correct height. Then attach the top square dowel with more glue and brad nails.
Step 5: Finish the Box
Sand everything smooth so that your rabbit won’t get any splinters. I chose not to use any finish on mine, but you could potentially use any food safe finish since the rabbit may nibble on it. Then place the plastic litter box in its place and fill up the the hay compartment.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    Penolopy Bulnick
    20 days ago
    Very nice job on your Instructable and the rabbit feeder box looks fantastic!
