Radio Flyer Restoration
5,660
26
17
Introduction: Radio Flyer Restoration
About: Husband, Father, Woodworker,
A quick walk through on how I restored a Radio Flyer Town and Country wagon.
Step 1: Finding the Wagon.
While walking through a local Habitat Restore I spotted something I could not leave without.
A 1980-1983 Radio Flyer Town and Country (if you know more about year please leave a comment)
Step 2: A Closer Look
Just a few more pictures of how it arrived before the restoration process takes place.
The red slats were pretty faded and front piece you'll see in the next few sets broken.
Main bottom pretty stained.
All the metal was rusted.
Step 3: Tear Down and Inspection
After tear and parts layout the the worst part was on the front slat. It appears the handle has just hit it one too many times.
Everything came apart pretty nicely. Other than the wheels they are put on with Safety Nuts or Lock washers (what ever you would like to call them) I was afraid to take them off being a once use item and unable to find the correct ones again.
Step 4: Fixing the Front Slat
I Pulled the single slat off the front runners. Once i had it off it fell into two separate pieces.
Grabbed some titebond 2 and clamped it all back together.
Let it dry really well then take the clamps off and inspect before working with it.
Trying to get of the cracked chunk out in the prettiest way I traced a line to the best of my free hand ability.
Grabbed my Router table and using a flush trim bit I took away as much of the meat of the wood before moving it to my (Ridgid) table top spindle sander.
Out come was pretty nice.
Step 5: Sanding Frame of Base
The frame of the base as pictured had a bit of build up from the years. Old varnish and clear cracking and just needed some attention.
I went back to the table top sander and ran the boards a few passes all the way around. I did this with the sander over a joiner or planer as I wanted to keep as much material as I could.
The last picture was right before I hand sanded for a smooth clean finish.
Step 6: Washing Sanding and Painting
Moving on to the metal.
First I took some good old soap and water and just scrubbed as much as I could off.
(NO PICTURES SORRY) I sanded it all down
again I didn't pull the wheels so had to tape it all off Strung it up and shot some paint.
And the out come here was BEAUTIFUL...
Step 7: Sanding and Prepping the Base Bottom
I was a bit unhappy with the out come here but its what is expected with 30 years of use.
As I was sanding I had to continue to sand deeper into the wood issue here I started to sand through the top layer of plywood which is NOT a good thing.
So i had to back off just smooth it all out and move on.
At the same time its not a new one and it is a restoration piece so just chalk it up as character!
Step 8: Assembling the Base and Frame
Pretty straight forward step here
I just reversed my tear down and added a bit of wood glue and some extra brad nails here to try and help it last another 30 years.
Step 9: Coating / Weatherproofing
I coated the entire base before assembling the wheels and sides with Helsman Spar Urethane ( https://www.amazon.com/Minwax-63205444-Helmsman-Ur... )
It gave it a Deep rich look and will protect it from the weather and even more staining over the years!
Step 10: Clear Coating the Slats
Again wanting to keep the wagon as close to factory as I could I cleaned them really good and added a few really good coats of spray on clear coat!
And WOW the red really pops
Step 11: Time to Put It Together.
Adding all the wheels and slate holders.
Step 12: And Its a Wrap!!!
could not be happier with the outcome of this little wagon.
Being able to build and restore this little wagon for my son puts a smile on my face and I truly hope one day he will understand what that means as well.
I can only hope it holds up for him and lasts another 30 year!
I would love any comments positive or negative I enjoy learning from others and giving back to this awesome community!
Fix It! Contest
Second Prize in the
Fix It! Contest
1 Person Made This Project!
  • Puzzles Speed Challenge
  • CNC Contest 2020
    CNC Contest 2020
  • Secret Compartment Challenge
17 Discussions
MikeA283
MikeA283
Question 7 weeks ago on Step 10
How did you match the rail red color?
RichI8
RichI8
1 year ago
I think you did a beautiful job. I have done several for my Grandchildren so I know how you feel about it!!!. Don't be afraid to change the base on your next resto.. I bought an odd piece of plywood at Lowes and they cut it to perfect size. Looks perfect. Again, very nice job!!!!!!
matthew.vitale.21
do you know by any chance on what kind of brackets are used on the sides and in the middle of the panels.
JenniferM508
JenniferM508
Question 1 year ago on Step 10
I have recently aquired one. I need to replace the base. The plywood is rotten. My question is what did you use to clean the red slats without ruining them? I don't want to repaint just get all the grime off without removing any paint
jones424
jones424
Answer 1 year ago
I just took a bristle brush (something like you clean a shower or tile with) and soap and water. but be careful as the red will bleed and chip off sorta easy or mine did. I then just took clear coat over the whole thing and brightened it back up. Good luck and be sure to share some photos once finished.
JenniferM508
JenniferM508
Reply 1 year ago
Thank you! I will. I will definitely post the Grand Finale!
Tura Street
Tura Street
1 year ago
This looks pretty cool. Thanks for sharing.
PakrninjaGaming
PakrninjaGaming
1 year ago
Great Job! I have the exact same wagon that my grandparents had on the farm for us kids to play around in. I inherited it and plan on restoring it some day, maybe for my grandkids years down the road.
jones424
jones424
Reply 1 year ago
Thank you!
That is great and if you do please share I love this stuff. I love the idea of passing down memories with items.
KennyC63
KennyC63
1 year ago
Looks great
jones424
jones424
Reply 1 year ago
Thank you sir! Hope all is going well!
Sweet! We have an old metal radio flyer that we put bigger, fatter tires on to make it more usable for hauling things over rough terrain. I love that they were invented by an Italian immigrant and named in honor of two other inventions, the radio and airplane. Your model is listed on their website, “First introduced in the 1960’s, the Radio Flyer Town & Country is a rugged, traditional wood wagon that has a “down-on-the-farm” feel that kids love. Its features put safety right up front, including smooth streamlined corners, a controlled turning radius that guards against tipping, and a quiet ride” https://www.radioflyer.com/heritage/
jones424
jones424
Reply 1 year ago
Wow! Thank you so much that was very helpful! I looked and searched and never found that page!
EcoExpatMike
EcoExpatMike
1 year ago
It looks great. I got my son a little one (apparently first such wagon in all of Pangasinan Province). Much amusement when he loaded up his little brown stuffed bear and took it for a tour of the neighborhood.
jones424
jones424
Reply 1 year ago
That sounds like a good time! Thank you for the kind words!
seamster
seamster
1 year ago
Beautiful work on the restoration! I fixed up a metal radio flyer wagon several years ago (did an instructable on it too!).
Very nicely done on yours!!
jones424
jones424
Reply 1 year ago
Thank you doe the kind words! I did stop by your page as well impressive work
