Introduction: Rain Chain,Copper Rain Chains
The beauty of a rain chain with a copper anchoring basin 15” or 18” in diameter which creates a perfect ambiance as it allows the rain water to collect in the basin and gently overflows into a flower bed or sandbox. The anchoring basin has a solid brass loop with a 12’ link chain for instant assembly with a rain chain. The washers can be loosened so rain water has another outlet to drain into besides the overflow from the top edges.
Step 1: Pure Copper Cascading Butterflies on Rings Rain
With the great success of cascading leaves we were inspired to create "Cascading butterflies on Rings" This exotic pure copper rain chain comes with its own triangular gutter installer followed by a Cup which collects the water from your gutter or downspout and moves it down in a controlled manner through the entire 8 ft length of rain chain. Copper butterfly pairs are mounted on heavy guage double rings and the cascading rain water clings to the surface and moves down with the help of gravity to the next butterfly pair and then the trio of rings and so on till it reaches the end of the rain chain where it can be captured into a copper basin to complete the picturesque image or into a barrel.
The cascading butterflies rain chain is a series of 19 butterfly pairs co-mingled with a trio of rings to efficiently transport rain water. Size & Specifications: Length: 8.5 feet (inclusive of 5" triangular gutter Clip)Links: 19 Butterfly Pairs Co-migled with a trio LinksMaterial: Pure CopperFinish: Natural CopperUPC : 633402120269What’s Included: 8 feet Rain ChainTriangular Hanger for Gutter Attachment
Step 2: Rainchain With PURE COPPER HAMMERED ANCHORING BASIN 18 INCHES
Monarch Rain chains offers a competitive selection of premium pure copper rain chains to suit your needs. Browse our vast selection of 36 + styles and you will surely find one that matches your homes unique landscape and your individual taste. Our range encompasses medium cups, large cups, x-large cups as well as a unique selection of link styles which have been inspired from simple links to the more decorative cascading leaves and cascading butterflies which have a touch of earthiness and exclusivity associated with them. Several styles are inspired from modern, contemporary lines and a few have drawn their unique look from architectural looks. Check out our medium cup and large cup rain chains designs inspired by nature’s organic surroundings, while others consist of a more progressive approach, with sleeker lines and contours. Our line of X-Large rain chains accommodate for larger amounts of rain fall/ water flow while still offering fresh and innovative designs for areas which experience a heavier downpour and for home owners who want the rainwater to be contained within cups vs. enjoying the visual pleasure of rain water running down the length of the rain chain links.
Copper Hammered Anchoring Basin 18 inches
Monarch's 18" pure copper hand hammered anchoring basin with a solid brass loop to effectively anchor the rain chain and provide a beautiful water feature.
Step 3: Chain Rain:3 PCS COPPER GUTTER ADAPTOR WITH CROSS BAR DEBRIS
Monarch’s new copyright 3 Pcs Copper Gutter Reducer with Cross Bar Filter and Rectangular Plate.
“Our latest innovation to block leaf debris and safely hang your Rain Chain” Monarch’s offers a unique way to prevent your rain gutter from clogging … our new copyright Copper Gutter Reducer with Filter provides a low-maintenance solution to gutter clogging problems at an affordable price. A perfect accessory to make your rain chain installation easy and work perfectly! This reducer drops into the gutter hole (An additional sleeve is provided "just in case" for larger gutter openings). Your rain chain hangs from the bolt at the bottom.
Monarch’s new copyright Copper gutter filter plate with round holes ©
Copper gutter filter plate with round holes © : A stand alone filter. The round holes prevent the passage of debris into your gutter the installation is very easy…simply place the pure copper filter plate on top of your gutter and it efficiently collects the accumulated debris. It is imperative that periodic cleaning be done, by simply picking up the plate and trashing the debris…and then replacing the plate back on the gutter
Monarch's pure copper gutter reducer provides a secure fool proof way to hang your rain chain from the gutter without water splashing. Our gutter reducer can be used where the drain is bigger than the standard..comes with a brass bolt for easy installation.
Monarch’s new copyright Copper Gutter Reducer with Filter
Step 4: Copper Link Rain Chains:Rain Chain Accessories
ALUMINUM TEARDROP RAIN CHAIN WITH FREE GUTTER REDUCER
Monarch Rainchains new introduction of the Aluminum teardrop rain chain is mesmerizing as it transports water from the gutter down to the ground in a beautiful melodious fashion. The material used is heavy guage Aluminum which does not patina over time and you can pair it with the Aluminum gutter reducer for perfect harmony.
Copper Ring Rain Chain Extension 3 feet
Water running down the length of the rain chain invokes a sense of tranquility, so we urge you to upgrade and update your gutters with these beautiful 8.5 ft pure copper links and cups and become the object of envy in your neighborhood.
Copper Tear Drop Rain Chain 8.5ft
Monarch's elegant 8.5 feet teardrop rain chain made of pure copper with links has unique styling and is a visual delight when water travels down it's length.
Copper Ring Rain Chain 8.5 feet
Classic 8.5 feet ring rain chain 2" diameter of pure copper interlinked to form a superior quality rain chain which transports water efficiently from the gutter
Copper Diamond Rain Chain 8.5 ft
Monarch's contemprory 8.5 feet link rain chain of pure copper joined together with little rings. The water cascades down the length of the rain chain and it is a visual delight.
Step 5: Rainchain:Copper Medium Cup Rain Chains
Lily Rain Chain:
The delicacy and uplifting soul of the Lily flower comes to life with the assembly of the pure copper Lily rain chain. This beautiful and graceful flower is represented in the hand etched perfectly crafted rain chain, exuding the vigorous and animated characteristics that symbolize the Lily flower. Each petal contained in the chain measures 2.75 ”H x 3.25” diameters. There are 24 cups assembled together in this rain chain to transport rain water down from the gutter. Over time, the natural beauty of copper will progress into a lovely brown patina coating on the surface of the rain chain. For a worry-free installation, each rain chain includes a triangular gutter clip. The total length of the rain chain assembly is 8.5 feet.
Our pure copper tulip rain chain exudes a charming attractiveness as it draws inspiration from the charming shape of the popular tulip flower which has been modified to accommodate capturing rain fall. The graceful flare of each Tulip cup suggests its openness to life and demonstrates the precision of the artists who hand-craft each cup, giving it its consistency presented throughout the chain. The tulip cup rain chain is made of heavy gauge pure untreated copper.
Copper Funnel Rain Chain 8.5 ft
Monarch's 8.5 feet pure copper funnel rain chain in natural copper is contemporary in styling and shape A perfect assembly of 19 cups and links to efficiently transport water from the gutter to the ground or into a receptacleNatural untreated copper cups react with oxygen to develop a beautiful patina over timeFunnel rain chain is our top sellerComes with a triangular gutter clip making installation easy and quick
Step 6: Pure Copper Accessories
Pure Copper Hibiki Cup Rain Chain 8.5 ft
100% pure copper cups hibiki cups...a perfect blend of japanese form intermingled with function is our new hibiki cups rain chain. A versatile elegant shape cup with a wide mouth to capture most of the water from the downspout and efficiently transporting it to the next cup through the simple yet elegant triangular link. The melodious sound of water as it runs down the length of this pure copper rain chain is music to the ears. Size & Specifications:
Copper Mizoko Rain Chain 8.5 ft
Classic and elegant in shape and style the Pure Copper Mizoko cup rain chain is an outstanding rain chain consisting of 10 cups, 10 teardrop links and 20 round links. The Mizoko cup rain is 8.5 ft in length inclusive of the triangular gutter installation piece.Each cup is individually hand etched and the rain chain creates a vision of cascading water during rain fall. Over time the Mizoko cup rain chain develops a beautiful brownish patina on the surface making it even more beautiful.
Aluminum Hammer Cup Black Rain Chain :
Classic in it's simplicity and elegant in design the Flat Black Hammer cup lends itself to any home style- Contemprorary or Traditional. Installation is quick and simple with the triangular gutter attachment piece. The hand hammering on each cup is hand done and this attractive rain chain is an assembly of 15 cups &
Step 7: Buy Copper Rain Chains & Rain Chain Accessories
Copper Juno Rain Chain 8.5 ft | Monarch Rain Chains New Introduction
Monarch rainchains is introducing this delightful yet functional rain chain which consists of 17 cups assembled together to efficiently transport water from the gutter to the drain or into a barrel for further reuse. Each cup measures 2" X 2 5/8" and has elegant lines running across the body of the cup adding to the character of the rainchain.
Copper Bell Cup Rain Chain 8.5 ft
Monarch's 8.5feet pure copper bell cup rain chain in natural copper finish, cup size 4 X 3" is distinguished and lends itself to any style home, classic or contemprory.
Copper Butterfly Rain Chain 8.5 ft
Monarch's 8.5 feet pure copper butterfly rain chain with its scalloped cups and butterfly hand etching is unique in styling. Classic combination of cups and links to efficiently transport water from the gutterBeautiful assembly of 22 cups making it a show stopper rain chainTriangular gutter attachment clip for easy installationButterfly rain chain develops a beautiful patina on the surface over time making it a spectacular piece of functional art.
Step 8: Monarch Rainchains Offers 100% Pure Copper Rain Chains
Step 9: COPPER LOTUS RAIN CHAIN
Pure Copper Lotus Rain Chain 8.5ft
8.5 ft length of a functional pure copper rain chain formed by the assembly of 20 Lotus shaped cups.Each cup has a wide flared mouth to efficiently capture most of the rain water and each petal is clearly indented and defined.Transports rain water efficiently down its entire length to the ground where it can be stored in a receptacle for reuse.Installation is simple with the triangular gutter attachment piece and easy installation instructionsDevelops a beautiful brownish patina on the surface over time.
The world is slowly understanding the need to conserve and protect the environment and stop water wastage. As this awareness is growing and seeds of change are being planted in people’s mind rain chains are fast gaining popularity. The rain water is collected at the end of a rain chain into a barrel or urn and is reused for gardening, washing the drive way but this rain water is definitely not for consumption. Copper is a natural reusable resource and since it is recyclable it is the metal of choice for us. Do away with plastic downspouts and replace them with our heavy gauge pure untreated copper rain chain and feel good about making smart choices.
